588,444 active members*
5,297 visitors online*
    May 2005
    62
    Can't reverse spindle
    I'm trying to cut 1-1/8- 12 left hand thread. The spindle tries to startup in the forward direction and kinda makes a strange sound. The machine goes into alarm mode and I have to cut the power off to make it restart. i make the spindle run in reverse manually just fine. This is the first time I have tried to run in reverse. It's a 6T control. Any ideas?
    Apr 2007
    148
    Quote Originally Posted by protrxrptr17 View Post
    Post your code and the alarm that you received, this might shed a little more light on your problem.
    May 2005
    62
    I got it to work by commanding M03 then M05 then M04.
  1. Spindle Reverse on a Bridgeport Interact?
    By UKRobotics in forum Bridgeport / Hardinge Mills
    Last Post: 10-27-2007, 02:04 PM
  2. Spindle Forward/Reverse = High/Low change
    By AdyAstley in forum Machines running Mach Software
    Last Post: 06-07-2007, 03:33 AM
  3. reverse spindle problem
    By bala955 in forum Fanuc
    Last Post: 03-09-2007, 12:24 AM
  4. Spindle sticking in reverse
    By creep_pea in forum Bridgeport / Hardinge Mills
    Last Post: 10-02-2006, 04:48 PM
  5. Reverse CNC
    By adwsystems in forum Uncategorised CAM Discussion
    Last Post: 05-16-2006, 01:05 PM
