588,567 active members*
5,085 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > need to unlock 9000 series programs
Results 1 to 7 of 7
    Mar 2010
    Need to unlock 9000 series programs for outputting to pc for backup purpose from fanuc oi control. Was able to output all other programs and parameters without any issues.
    Jul 2007
    378
    On the Fanuc OM series control, You need parameter #0010 bit #4 to be a 0 to edit 9000's programs and 1 to protect the programs.
    ex.
    0010= 10010001 9000 Protect on
    0010= 10000001 9000 Protect off.
    If you have a parameter manual for the Oi control, look under the Marco programing section, it should e listed there.
    If you can not edit the 9000's programs, it will not punch out the 9000's programs.
    good luck
    2932
    For the 0-i, set parameter 3202 bit 4 = 0. Be aware that while this parameter is 0, you can delete the 9000 programs, too.
    Mar 2010
    Thanks for the help. 3202 was the # bit#4 to 0 enable the 9000s to be output for backup. Changed back to 1 as soon as completed. Is it necessary to backup the PMC parameters also?
    2932
    3202.4 is only for 9000 series. PMC parameters should back up fine regardless of 3202.
    Mar 2010
    Understood. I just wasn't sure if the PMC parameters is something I should backup or in case of a catastrophic failure, if the machine tool builder would have a copy for restoration.
    2932
    I would back up all the parameters.
  1. deleted 9000 series sub-programs
    By gcrudgington in forum Fanuc
    Last Post: 11-30-2023, 02:36 AM
  2. 9000 programs?
    By jimmyjolly in forum Fanuc
    Last Post: 04-20-2023, 07:02 PM
  3. 9000 series programs deleted.
    By gcrudgington in forum Bridgeport / Hardinge Mills
    Last Post: 07-02-2009, 11:01 PM
  4. 9000 programs
    By crazycnc in forum Fanuc
    Last Post: 12-21-2008, 12:20 AM
  5. Punch pram's and 9000 programs
    By Drew in forum Fanuc
    Last Post: 12-12-2008, 06:07 AM
