What does this alarm mean (X DAC Under Flow)? And what should I look for as the cause?
Sid
Sid
A DAC underflow usually happens when a axis moves when it is not supposed to.
The Control sees a pulse count when it did not command one.
George
Thanks George, but what could cause it.
Sid
The 12 VDC comes from the logic power supply. But where it goes is very dependent as to which control you have.
George
