Hello all,
I'm using a treadmill motor and controller obtained from Surplus center for my mini-mill. I want Mach 2 to be able to control spindle on & off, but when the spindle shuts off then on, you have to turn down the pot all the way then back up to get the spindle on again. It uses a 5K ohm pot. I found that if I disconnect one of the pot leads from the control, then reattach it, the spindle goes back on at the previous speed. I figure that this is like having a pot with an on/off switch built in.
My question (or two) then is: if I put a relay in series with a lead from the board to the pot will I damage anything? Will it make any difference which lead I use?
Thanks in advance
