Hi all.
Like a lot of you here, I also want to build a milling machine. and what I think is as standart procedure is to start with some calculations. I did a few. and I was wondering what kind of motor powers you are using.
I calculated that a milling machine capabel of milling a stroke 5mm and 5mm deep in standart C45 steel with a fz of 0,2mm and a vc of 0,6m/s would need a motor with 3800W. could I calculated it correct???
and what kind of motor power are you all using.
Greetings Maarten.
P.s. if there are some mistakes in my english, don`t judge me.....
