587,171 active members*
2,883 visitors online*
Results 1 to 11 of 11
    Feb 2013
    38
    Signs of a dying tube.
    Hi everyone.
    I've just changed the controller board on my machine - all good, but I now have a new problem, which may (or may not) be related.
    The cut gets weaker after about 5 seconds.
    So if I cut a long thin (pencil shape/size) slot in a piece of MDF, it'll go right through fine.... then it will get weaker and weaker, so by the time it has returned to its origin, it isn't cutting through at all.
    This rules out focus, centering, dirty lenses/mirrors (all checked anyway) all the usual things - and leaves me thinking that the beam is getting weaker during the cut.
    Is this a sign of a dying tube?
    I've had this tube for a year or so. What does a dying tube do?
    Sep 2014
    30
    Re: Signs of a dying tube.
    Hi Nickwit
    I am afraid you need change your laser tube. it gets old.
    how many walts of your laser tube ?
    Abby
    www.wklaser.com [email protected] SKYPE: cyosusu
    Facebook:https://www.facebook.com/people/Cuicui-Zhang/100005165685762
    hi,
    yes,abby is right,you need to replace a new laser tube,eventhough you didn't work on many hours,as without working,laser power also leak.
    tina from g.weike laser
    EMAIL: [email protected] SKYPE: lysunshine521
    Feb 2013
    38
    Hiya - it's 60 watts RECI
    Sep 2014
    30
    Hi Nickwit
    RECI company has not 60W laser tube. they manufacture 80W and above.
    I think it is other brand. With shorter lifetime.
    you need replace a new one now.
    if you want upgrade to 80W RECI laser tube. add another 80W power supply is ok
    80W RECI laser power can up to about 100W. this can make your work easier.
    Quote Originally Posted by Nickwit View Post
    Feb 2013
    38
    Ah - that will explain why I had so much trouble finding a replacement
    I went for another 60 - probably should have gone to 80... maybe next time.
    Jun 2014
    611
    Hello Nick, how long the laser tube work everyday?
    here we have an lesson to guide you how to replace a new laser tube:
    How to replace the laser tube
    hope it can help you some or less.
    good luck.
    www.thunderlaser.com
    Oct 2014
    30
    Hi, Have you checked the mirror alignment?
    Nov 2014
    8
    Power dropoff can definitely be a sign of a bad tube. In fact, in my experience that's the root cause most of the time, but every once in a while it's not.
    A few things to look at:
    - How does the plasma/beam look in the tube when firing? Is it white or a bright pink or purple? My 40W tubes glow a deep purple (like Mace Windu's lightsaber) when they're working properly. When they're dying, they shift toward bright white. Also look for a mode change within the beam. Does it visibly change size, color, or even position within the tube when running? On a stable tube, the beam should not change form or color while power is being applied (a little dancing around near the output end is normal).
    - What temperature is your cooling water? Heat will kill a tube very quickly, and power will also drop off as tube temperature rises. We keep our coolant water at 60 degrees F using a lab chiller. (With your power dropping off so quickly, though, I wouldn't expect this to be the issue.)
    - Do you have a meter measuring current from the high voltage supply to the tube? If so, observe whether or not the current is stable, or whether it too drops off as your laser power diminishes. If current is dropping off as power does, then you likely have a dying HVPS and not a dying tube (though I have had both go at the same time before).
    normally it should be purple while laser firing,
    if laser tube die (gas leak), it's while,
