588,671 active members*
6,501 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > fanuc 9000 series programs
Results 1 to 8 of 8
    Jul 2005
    29
    hi all
    i have a question regarding 9000 series programs.
    i run a daewoo puma 350m 3 axis lathe, with a fanuc 18t controller. the machine's build date is 2000
    my question is, do the 9000 series program numbers have to refer to a specific function?
    or to put it another way, if there is in memory, a program numbered o9001, which is say, a dwell routine, could i overwrite this with another program o9001, which records the position of the tailstock?
    the reason i aks, is that i have a training course reference book, which shows programs for different functions, but having the same numbers.
    now i realize that there can only be one program in memory with the number o9001 at any time, but i am wondering if the numbers are function specific
    thanks in advance for any replies
    best regards, axis
    2932
    You should check parameters to see if those program number are being called by M-codes (6071-6079, 6080-6089) or G-codes (6050-6059). If these parameters have values in them, then that program may need to remain unchanged.
    6071 M code that calls the subprogram of program number 9001
    6072 M code that calls the subprogram of program number 9002
    6073 M code that calls the subprogram of program number 9003
    6074 M code that calls the subprogram of program number 9004
    6075 M code that calls the subprogram of program number 9005
    6076 M code that calls the subprogram of program number 9006
    6077 M code that calls the subprogram of program number 9007
    6078 M code that calls the subprogram of program number 9008
    6079 M code that calls the subprogram of program number 9009
    6080 M code that calls the custom macro of program number 9020
    6081 M code that calls the custom macro of program number 9021
    6082 M code that calls the custom macro of program number 9022
    6083 M code that calls the custom macro of program number 9023
    6084 M code that calls the custom macro of program number 9024
    6085 M code that calls the custom macro of program number 9025
    6086 M code that calls the custom macro of program number 9026
    6087 M code that calls the custom macro of program number 9027
    6088 M code that calls the custom macro of program number 9028
    6089 M code that calls the custom macro of program number 9029
    6050 G code that calls the custom macro of program number 9010
    6051 G code that calls the custom macro of program number 9011
    6052 G code that calls the custom macro of program number 9012
    6053 G code that calls the custom macro of program number 9013
    6054 G code that calls the custom macro of program number 9014
    6055 G code that calls the custom macro of program number 9015
    6056 G code that calls the custom macro of program number 9016
    6057 G code that calls the custom macro of program number 9017
    6058 G code that calls the custom macro of program number 9018
    6059 G code that calls the custom macro of program number 9019
    Jul 2005
    29
    many thanx, dcoupar, for that information.
    i think i am beginning to see the light
    regards
    axis
    May 2007
    1003
    It has been my limited experience that machine builders do not use the 9001 through 9029 for any subroutine they incorporate. They will use a different 9000 number, and leave those numbers alone. There is a good chance that the 9001 program in your control was put there by a previous user. There is no function assigned to any of the 9000 numbers.
    To me the idea for using 9000 numbers is to have a subroutine that can be used by any program. Thus they are always loaded in the control. Protection is always turned on.
    An example is the O1 through O4 Safe Index Subprograms that Hardinge suggests you use. I put them in O9001 through O9004 and set the M-codes (6071 to 6074) to call them to 91 through 94 so M91 calls O9001, M92 calls O9002 etc.
    2932
    Quote Originally Posted by g-codeguy View Post
    Many of the builders I'm familiar with DO use O9001, O9029, etc. for ATC, APC, etc. macros on new machines from the factory. I thought it was best to check before overwriting important macros and subs.
    May 2007
    1003
    That's why I qualified my statement. Plus it makes more sense to me for the builders to leave those programs for the buyer to use. Not that I've ever come close to using them all! But I guess that would depend on what subroutine the builder supplied. If it got used a lot, then being able to call it up with something like M91 (or whatever number you choose) saves typing and a few characters of memory.
    I've stated before that I have zero experience with mills. I would think that a mill could make use of more subroutines than a lathe.
    I stand corrected, and you are absolutely right. Best not to overwrite a needed program. Of course, if you're going to be doing something like that, then you should first have an understanding of what is needed for your machine. No sense in reinventing the wheel. I've never overwritten a supplied 9000 program even when I never used the program even once. Might someday want to.
    Jul 2005
    29
    hi g-codeguy
    the 9000 series are also used by renishaw probe macros for part measuring/setting etc.
    initially, i was wondering if there was/is a specific function assigned to each 9000 number, but after studying the manual, and the information supplied here, i have concluded that there is a relationship between 9000 number, certain parameters and additional G and M codes.
    specifically, i have now entered 9000 series programs that will allow me to record the home position and forward position of the tailstock, and then call it forward and send it home again, just by issuing 2 M codes and 2 G codes.
    the position record is numbered 9001, which was being used as a macro to reference the c axis.
    i have another 9000 program that allows me to use the G30 2nd reference position as a time saver
    many thanks for your replies
    regards
    axis
    Jun 2022
    Re: fanuc 9000 series programs
    algien que tenga los macros 9000 de republic lagun s8 studio
  1. deleted 9000 series sub-programs
    By gcrudgington in forum Fanuc
    Last Post: 11-30-2023, 02:36 AM
  2. Replies: 5
    Last Post: 04-12-2014, 08:22 AM
  3. Fanuc omb 9000 series macros needed bad
    By chippslinger in forum Fanuc
    Last Post: 09-13-2011, 09:56 PM
  4. need to unlock 9000 series programs
    By rhutch in forum Fanuc
    Last Post: 04-10-2010, 06:51 AM
  5. 9000 series programs deleted.
    By gcrudgington in forum Bridgeport / Hardinge Mills
    Last Post: 07-02-2009, 11:01 PM
