588,429 active members*
5,623 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > HELP HOW TO I ADD MORE TABS AFTER ADDING THEM AUTOMATICALLY
    Sep 2003
    1475
    VCARVEPRO V12
    I used the automatic tab feature to add two tabs to the parts, now after reviewing the tab placement i find i need to add a few more tabs manually. I went back and added the tabs manually but in doing that it erased all the automatic tabs.
    How do I add additional tabs manually after I add them automatically?
    Nov 2013
    4608
    Re: HELP HOW TO I ADD MORE TABS AFTER ADDING THEM AUTOMATICALLY
    to my knowledge you cannot, you either add tabs automatically at the nominated spacing OR you place the tabs manually. There is only one data structure for tabs (again to my knowledge)
    and that data structure is populated with data from either of two methods, namely automatic placement OR manual placement.
    Craig
    1240
    Beside noting that this is the Autodesk section of the forum,where you may not have too many Vectric users browsing,I would suggest that you might more easily find answers on Vectric's own forum https://forum.vectric.com/.
    From memory I believe there is a check box in the tab control section that you can check to get to a further section that will allow you to edit the tabs on the component.The Vectric way of doing things seems to be a little different to some others and they use their own terminology for some things.I believe if you can find the tutorials,you will find something there that will help.
    - - - Updated - - -
  1. Replies: 4
    Last Post: 01-01-2023, 01:46 PM
  2. Can't add machining tabs in Fusion 360
    By Arland in forum Autodesk CAM
    Last Post: 10-02-2015, 01:41 AM
  3. Change the post process and add new line automatically
    By sml2010 in forum Uncategorised CAM Discussion
    Last Post: 04-25-2014, 04:34 PM
  4. Adding tabs to existing file
    By budpage in forum CamBam
    Last Post: 03-22-2011, 03:10 AM
  5. Adding Tabs With MasterCam V9
    By mmcclain02 in forum Mastercam
    Last Post: 01-20-2006, 08:53 PM
