I have THK bearings (SR25 type) and need to add grease to them. For now, I used a general automotive grease "STA LUBE high temperature bearing grease" which is very thick and black. I find this grease will work but will dramtically slow the speed of the bearings as it slides back and forth as well as require more force to move the bearings since the grease is the very thick kind. I am looking for an appropriate grease that is light and will not slow down the bearings movement. Can someone recommend a quality grease appropriate for THK bearings. There is a Home Depot and Lowes hardware store nearby so I can pick one up there, but what kind of grease should I ask for?
