Hi folks,
I haven't been on cnczone in a while.....haven't been on the tinternet in a while, been very busy with work.....now its time to get back to the real work of cnc'ing!!
Background: Anyway, Im about to buy a shed to relocate my tools and have some sort of temporary proper workshop. Unfortunately, right now at least, I can't really get an electrician to put in permanent power since the shed will be in the in-laws house, and the shed itself I think is enough to annoy them with for one day!
Problem: So, obviously I need power, and running an extension cord or cord's from the house is the order of the day. Sounds simple! Ok, so its September right now, and in about a month god will unleash raining fury on Ireland as per his usual routine. Now Im thinking I dont want some crappy extension cord electrocuting me when it's lying in a pool of water from the house to the shed. So I searched the internet, and there doesn't seem to be much in 220V outdoor cords out there, I only found this one on amazon but its not long enough: http://www.amazon.co.uk/Waterproof-o.../dp/B000R2SFF8
So Im thinking I'll make two of my own as follows:
RCD plugged into mains in house.
Extension cord plug connected to RCD.
15Amp (Or higher) cord connected from the plug and run out to shed, where it will have 4 sockets at that end.
I figure I can use two of these giving me 8 power points in the shed. Four points always being used for the cnc machine, and the others only being used one or two at a time as I'm working. I can also connect the cord above gnd level outside to the house wall wherever possible to minimise the amount its physically sitting in water.
So what do you all think in general?
Am I missing any safety devices I can add into the circuit?
Do you think 15Amp cable is enough or should I use a different amperage, the mains is 13Amps I think?
Thanks all. Hope everyone's being keeping well while I was gone.![]()
