586,102 active members*
2,476 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Help needed with wiring.
    Jan 2022
    Hi All
    First post here so please be kind, I have purchased a Chinese VFD (HY01D523B)its a 1.5KW 220v unit with an air cooled 1.5KW spindle.
    the issue I have is connecting the VFD to the BOB, I'm currently using the controller pictured. Looking at the wiring diagram it shows 3 outputs going to GND, Start/Stop and AVI.
    Can anyone explain what terminals this equates to with the VFD please as I don't what to blow either up..
    Thank in advance.
    Attached Thumbnails Attached Thumbnails BOB.jpg   mach3USBCardWiringdiagram-800.jpg   VFD.jpg
    15362
    Re: Help needed with wiring.
    Quote Originally Posted by Steve8683 View Post
    Hi All
    Thank in advance.
    This will depend on your Breakout Board, you will have an AVI & ACM (Analog 0-10v speed control) and FWD & DCM, (is just a switch / Relay between the FWD / DCM for On / Off), with some VFD Drives these (2) connections can't be mixed.
    What Breakout Board are you using??
    Mactec54
    Jan 2022
    The board acts as a BOB doesn't it or have I missed something? new to the world of cnc.
    15362
    Correct
    If you tell me what Breakout Board you have or post a link to it, I will tell you what you need.
    Mactec54
