587,684 active members*
3,133 visitors online*
Results 1 to 13 of 13
    Aug 2008
    82
    Rabbit/lasercut rotary settings
    Hi all,
    I'm looking for some help with my XZ-M-I rotary attachemnt settings.
    Fom what I understand I have to change the Y-axis Pulse Unit setting to work the attachemnt.
    Could anyone tell me how to calculate that setting based on diameter of the lasered item.
    I'm using Lasercut 5.1 on a 4060 SE 40W
    Many thanks
    Dave.
    Feb 2005
    469
    On my WK Laser machine the formula was 3.14*D/2 and insert that number where it shows in the picture below.
    Skip
    Aug 2008
    82
    Quote Originally Posted by SkipW View Post
    Skip
    Hi Skip,
    Many thanks for the reply.
    As soon as I saw your post I jumped up with excitement to go try it.
    Unfortunately, it didn't work for me.
    My test engraving is a circular graphic which is 40.5mm dia on to a 66mm dia glass. With the formula you suggested I get an oval about 21mm wide.
    I did some trials using smaller values untill I got it right but of coarse, it was only good with that particular dia.
    Thanks for trying.
    Dave.
    Feb 2008
    66
    Wauw.....
    i still not realize this.
    i just using my rotary attachment, and not change any setting on machine.
    but as far as, it's look fine on my machine. i could engraving on glass and cutting cylinder acrylic.
    Aug 2008
    82
    Quote Originally Posted by Huahahahahaha View Post
    Wauw.....
    You are fortunate that it work out that way. The problem you will have is if you go bigger in diameter, you will end up with a narrow image.
    Dave.
    Dec 2005
    329
    I have a lasser rabbit rotary but i do not need changed anything. I connect the rotary in the X controler and work good
    Aug 2008
    82
    Quote Originally Posted by edecalho View Post
    Thanks for you input.
    Could you tell me what the various diameters are that you use with this, and is it the XZ-M-I rotary attachemnt.
    Many thanks
    Dave
    Dec 2005
    329
    Rotary
    I attach pictures of my rotary. I changed to allow recording cylinders with grip objects. If I have problems when the objects are not perfect or cylindrical shapes with irregular. Cylinders to be swiveled by the roller bearing the same gear ratio, so it is not necessary to make any change in the configuration of the shaft.
    Sorry but my english it´s bud
    Eduardo
    Montevideo - Uruguay
    Por si alguien habla en español
    MSN [email protected]
    May 2005
    101
    dave
    Ask the Rabbit company to give the value of the stepper motor so, you can input the right value. It looks the stepper motors in the machine (X and Y) is not the same as in the rotary attachement.
    Muqtadir
    Aug 2008
    82
    Quote Originally Posted by muqtadir View Post
    dave
    Muqtadir
    Muqtadir,
    Thanks for the suggestion. Looks like I have to do just that.
    In the meantime I'm going to experiment to try to find the answer.
    Thanks again
    Dave
    Sep 2008
    117
    Er, the circumference of a circle is Pi x D = 3.1416 x Diameter
    That might give a better looking circle.
    Dave
    Sep 2014
    Re: Rabbit/lasercut rotary settings
    please i have a problem with laser cut 5.3
    when i Cut a square 100 x 100 the result 8.3 x 8.2
    i cheked my machine
    work table PULSE UNIT : 0.0039656250 MOVE 50.760000 NEED PULSE 12800
    wklaserliu Guest
    Hi Skip,
    yes you are right , and when machine dleiver we will put a roitary use manuual with along with mahcine it is easy for user to operate.
    also on our web there are all use mannual for customer to dlowlaod ,help them with their machine .
    Quiven form gweike alser
    skype: wkquiven
    [email protected]
    whatsApp:86-15698041856
  1. Anyone Near Wisconsin with a Rabbit Laser or LaserCut 5.3?
    By mecheng10 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-02-2013, 03:45 PM
  2. LaserCut 5.3 settings for glass
    By NFATeacher in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-02-2011, 05:14 AM
  3. Rabbit Laser hx6090 SE lasercut 5.3
    By John Niemeyer in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-12-2010, 07:07 PM
  4. Rabbit laser Resolution & lasercut 5.1
    By dvdlock in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-22-2008, 02:07 AM
  5. Rabbit Settings
    By ArturoV in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-06-2007, 01:41 AM
