I have removed all of the electronics except the power supply, E stop, EMI filters and the motor controller board. Upon checking the voltages, there is supply ac (120vac) coming into the board. All wires are still connected and powered except the "J1" header, which has a 9 pin connector that has 5 wires actually connected. This connector has
Pin 1 Red, Pin 2 Black, Pin 3 Black, Pins 4,5,6 & 7 are blank. Pin 8 is Yellow and Pin 9 is Black. Judging from the wiring diagram, do you see a way to manually switch the spindle on? Possibly even computer control? Here is the schematic. There is bound to be a way to hot wire this board. Please help before I have to cry to Al!
