587,999 active members*
2,666 visitors online*
    Dec 2005
    141
    Spindle Servo Issues
    I am having one more problem with my setup and i am looking for some input,
    I have a old cnc router table that i have upgraded the controller and when ever the spindle comes on the y axis with pluse/move so when i am cutting a circle it comes out as a spiral seeing that the start point and the end point are not the same. X and Z seem to be fine just Y. if i run the program without the spindle the Y Axis is fine and my start point and end point are spot on.
    I have tried to change the +/- leads for the servos to a shielded wire thinking that it was picking up an interference same result. the encoder wires are already shielded
    Machine Specs
    Mach 3
    Gecko G320x Drivers
    C10 BOB
    55V Power supply
    Servos (Reused from old setup *replaced encoders*)
    US Digital E5 Encoders
    C41 PWM Spindle controller
    Perske Spindle (Reused from old setup)
    Delta VFD (Reused from old setup)
    C4 Charge Pump (used as safety switch)
    thanks
    Mike
    24220
    Check all grounding and bonding of the main router gantry frame and the motor frame to a central Earth ground point, make sure the PC case is connected to this point also, including the VFD and spindle motor frame.
    Al.
    Albert E.
    Feb 2006
    7063
    Do you have the G320X configured properly for the US Digital encoders? You have to enable "HEDS mode", which disables encoder failure detection.
    Also, as suggested, make sure your Geckos, power supply, and VFD are all grounded to the same point, with each having its own dedicated ground wire. NEVER daisy-chain grounds.
    Regards,
    Ray L.
    Dec 2005
    141
    Thanks Guys, but bad news, i have grounded the table (table leg), the gantry (side plate), the spindle frame, VFD, and the computer to earth ground...... just to make sure we had earth ground we went and got a copper rod, drilled a hole in the concrete, and drove the copper rod 4ft in the ground.... still same thing....
    Also i do have the HEDS switch turned on
    i have also tried used shielded wire for the encoders, servo driver leads, and the signal to the VFD... same thing....
    tried to turn the spindle on from the VFD its self same thing.
    Here is a video of the problem
    [ame=http://www.youtube.com/watch?v=csuiKUjWB6I]CNC Router Problem - YouTube[/ame]
    NOTE: i am not moving anything during this video......
    Any Suggestions!!
    Mike
    Aug 2007
    162
    you might try disconnecting the encoder cable and wiring encoder A & B to Enc Gnd with really short jumpers right at the gecko. Don't command any motion on the axis, or the servo will run away! Grounding both inputs just makes it look like the axis is holding position & not moving.
    If the Y axis stays still with spindle on, my money is on the encoder cable picking up noise.
    Edit: to be safe, you might want to disconnect the lead screw from the motor just in case the motor does run away when you enable it. This way the motor just spins and doesn't send the spindle into a hard stop at a high rate of speed. Any movement of the motor shaft with encoders A & B grounded and spindle on indicates the noise is coming from somewhere else.
    I've had problems with US digital encoders & noise before. If that's the problem, you might try CUI encoders. I've had better luck with them. They're pretty easy to order from digikey and pretty easy to retrofit as well.
  1. Servo Drive Issues
    By spaceacealpha in forum Fanuc
    Last Post: 07-14-2012, 07:45 AM
  2. servo motor issues with a partner5 milltronics
    By jetskiman in forum Milltronics
    Last Post: 09-26-2011, 04:20 PM
  3. KERNEY-TRECKER HYDRAULIC SERVO ISSUES
    By J.R. SWIGER in forum Uncategorised MetalWorking Machines
    Last Post: 09-11-2010, 10:00 AM
  4. Pluto Servo Almost working Encoder Issues
    By TZak in forum LinuxCNC (formerly EMC2)
    Last Post: 03-15-2007, 06:15 PM
  5. Rutex Servo issues.
    By ty1295 in forum Servo Drives
    Last Post: 05-28-2005, 05:10 AM
