588,666 active members*
5,941 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Toolpath Transform problem...
Results 1 to 7 of 7
    Jun 2007
    110
    I'm having trouble getting my "like" tool operations grouped together when doing 2 transforms.
    I Transform - Translate down to get 4 copies of the part. At this point, my tooling is grouped together as expected. Now, I take "that" transformation and Translate-Mirror - so i get 4 copies to the right. So I now have 8 copies of the part.
    It wants to complete the right column of parts, then moves over and does the right column of parts - which doubles my tool changes. I've tried about every combination of checkboxes there - but can't get it to do it.
    What I have been doing, is just generating the source code for all operations and then dragging and re-arranging the order to group the tools together.
    So I can get it done, but its a pain if I need to make a change to one of the operations.
    Using MX2-SP1....
    Thanks!
    Feb 2006
    18
    My first thought is try mirroring the first part before translating. Then translate both part to create the 8 you are looking for. I haven't tried this but it is a thought. I use MCX not X2 so don't know about differences.
    Mike.
    Jul 2003
    263
    check your operation order or operation type check boxes i think it should be set to operation type not sure, haven't done a transform translate tool path in a long time
    If you can ENVISION it I can make it
    Jun 2007
    110
    cmmachine,
    I was trying to avoid having 2 sets of geometry - in case changes are needed later. I just wanted 1 part/geometry...
    cnc-king,
    Operation order does work for the 1st translation, but those selection boxes are grayed out and not available for the mirroring translation...
    Apr 2003
    3578
    you are going to have to break it down by operations, mirror them then after you have done that then translate te all the ops and matching mirrors and translate them . could be a little more but still better then programing them all.
    Cadcam
    Jun 2007
    110
    cadcam,
    Didn't try that combination - it works well. This is the least amount of additional work - especially if changes are needed later.
    Thank you!
    Jun 2007
    110
    cadcam,
    Thank you!
  1. Help toolpath problem
    By cam168 in forum Mastercam
    Last Post: 01-18-2008, 02:03 AM
  2. HELP Mastercam X2 toolpath problem
    Last Post: 01-16-2008, 07:59 AM
  3. V9 Toolpath Problem
    By Clawsie Machine in forum Mastercam
    Last Post: 12-01-2007, 08:34 AM
  4. Autobots, Transform!
    By Switcher in forum RC Robotics and Autonomous Robots
    Last Post: 07-13-2007, 12:48 PM
  5. DeskCNC Toolpath problem
    By epineh in forum CNC Machine Related Electronics
    Last Post: 12-19-2006, 10:38 AM
