588,136 active members*
5,975 visitors online*
Thread: ultra newbie
    Jul 2007
    4
    ultra newbie
    i apologize in advance and beg forgiveness for stepping on a thread here-and will go to wherever directed for answers-but does someone have any clues about turning on coolant and lube to the ways etc on a 25 yr old shizouka mill w/ a fanuc 6b control.about the only codes i can do are x,y,z, and pause,and of course spindle on and off-so you can see i'm as my title describes me;thanks to all in advance-pat
    In general M codes for coolant On is M8 & Coolant Off is M9. For lube ways there is no M codes it is Timer Based activation it is control by so many methods by the manufacturer.
    1) Timer control by PLC
    2) Mechanical Gear type ( Motor contineously run )
    3) External Timer based Lubrication unit
    I dont know which type of Lube system you are having.
    If your lube is not working check the type & Diagnose the fault.
    Jul 2007
    4
    thanks!
    i've tried m1 thru m16 but no luck(of course i skipped 3 and 4 for spindle control)-pat
    May 2007
    15
    Exclamation
    Pato,
    There is a book I recommend getting. Even though it takes you through the most advanced of the advanced in FANUC programming, it lists all the codes for FANUC by control. It will give you a fluid knowledge of the system from start to finish and makes a valuable resource book. Note: Your system may not even be Custom Macro B compatible (not to mention Macro B may or may not be of use to your application), but it is still worth getting if you are going to be using FANUC.
    http://www.amazon.com/Fanuc-CNC-Cust.../dp/0831131578
  1. Any idea on Ultra Master from Rockwell?
    By Darc in forum Servo Motors / Drives
    Last Post: 06-20-2010, 08:23 AM
  2. Who can enlighten me how to process ultra-hard material?
    By TechDoor in forum Benchtop Machines
    Last Post: 11-30-2006, 03:41 AM
  3. Newbie
    By Closetolerance in forum Benchtop Machines
    Last Post: 12-12-2005, 10:06 PM
  4. Allen Bradley Ultra 1500 Drive Connectors
    By Kookaburra in forum Servo Motors / Drives
    Last Post: 07-19-2005, 02:58 AM
  5. Help this Newbie Please!
    By Guy Smiley in forum Xylotex
    Last Post: 12-24-2004, 07:57 AM
