587,345 active members*
3,565 visitors online*
    Jan 2012
    163
    has any one seen this?
    I load Mach3 default looks right box with 2 circles,Attachment 438480
    now I load XML file for my break out board its not rightAttachment 438482
    what can i do???
    Re: has any one seen this?
    Change the IJ mode in General Config.
    Loading a different .xml file will change ALL of your Mach3 settings, so you'll likely need to manually change a lot of them to what you need them to be.
    Jan 2012
    163
    you got a gold star today it worked Changing the IJ mode in General Config. I was pulling my hair out Thanks!!
