588,183 active members*
4,332 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Multus Tool Offset Checking: Across all Cutting Positions
Results 1 to 7 of 7
    May 2017
    4
    Question Multus Tool Offset Checking: Across all Cutting Positions
    Hi guys,
    I already perform tool offset checking on our LB3000's, but robustly checking them on the Multus is a little more complicated.
    If the operator is following procedure and using the touch setter, or AUTO CAL, you should be able to read out the offsets for any position / mode and check those. But, I want to protect against an operator manually entering a bad value in just one position, so I need to check everything x8:
    • BT=0 / BT=1
    • M602 (A) / M603 (B)
    • G140 (main) / G141 (sub)
    I'm just not seeing a way to specify these individually stored offset positions, using system variables:
    Any ideas?
    Mar 2009
    1982
    Re: Multus Tool Offset Checking: Across all Cutting Positions
    am I getting your point correctly?
    You want to check al the tools offsets in order to be sure they are correct. Right?
    Of You don't trust Your operator, just lock the Parameter function.
    Jun 2015
    4169
    hy i can help, discussing your actual methods for LB, and aproaches for other machines
    besides offsets, there are also other things / kindly
    May 2017
    4
    Quote Originally Posted by Algirdas View Post
    I don't want to lock the parameters screen. I want to safeguard against mistakes by checking each tool offset to ensure it is within a safe range.
    If an operator builds a tool with the wrong stickout, or worse yet, touches off a tool into the wrong offset number. These can easily be caught with logic in the code.
    The Multus just stores a lot more of this data per tool, which I haven't yet found the system variables for.
    Six data fields: X, Y, Z, RZ, RX, P
    Times 8 cutting position combinations.
    Equals 48 data fields per tool
    May 2017
    4
    Quote Originally Posted by deadlykitten View Post
    Hello, I don't so much need help with the methods, as I do finding the system variables that store all the additional Multus offset data.
    Jun 2015
    4169
    hy look over these :
    ... main : vdtf + x y z
    ... wear : vdtw + x y z
    ... R : vdnr + x y z or vdnrr
    ... P : vnrpn or vdnrp
    the argument [ mmkkkk, mmkknn, mmmkkk, etc ] may not be identical to the one after T, as multus T comand may vary, and is subject to parameter status, and also your way of coding comes into play
    such things are into the complementary category, like, for example, using only 10 turret post out of 12, and all 10 ok, only that those posts that are not used will actually cause an interference
    different aproach is required here
    please fix 1st those system variables, and then, if you wish, will discuss
    along the years, i have been proofing agains colisions with low frequency chance, and not caused by operators, thus there is a special suite of critical cases
    i understand the rush for the system vars
    some automation can be added, thus making things work in background for you, like automatically T comands indentify in g-code, or custom tool change
    please, feel free to ask anything / kindly
    ps : hy mr bunny
    May 2017
    4
    Thank you for the reply!
    I think you are suggesting, for example on tool #120, that the Z offset would be:
    VDTFZ[120]
    my manual suggests it would be:
    VTOFZ[120]
    But either way, is that for:
    Main spindle mode / BT=0 / A
    Main spindle mode / BT=0 / B
    Main spindle mode / BT=1 / A
    Main spindle mode / BT=1 / B
    Sub spindle mode / BT=0 / A
    Sub spindle mode / BT=0 / B
    Sub spindle mode / BT=1 / A
    Sub spindle mode / BT=1 / B
    The tool's Z offset has discrete values for each of those.
  1. Replies: 9
    Last Post: 04-03-2024, 09:33 PM
  2. Multus Multi Edge Cutting Tool
    By kurmay in forum Okuma
    Last Post: 01-11-2016, 04:11 PM
  3. Need help with Macro for checking tool length before tool change
    By mioduz in forum Tormach Personal CNC Mill
    Last Post: 04-18-2014, 08:43 PM
  4. In Need of a macro for checking tool length
    By mioduz in forum Mach Wizards, Macros, & Addons
    Last Post: 04-16-2014, 08:20 PM
  5. Replies: 0
    Last Post: 03-28-2014, 08:57 PM
