588,570 active members*
7,422 visitors online*
Results 1 to 14 of 14
    Oct 2011
    Internal Spindle Coolant Fluid
    I've got a liquid cooled spindle, and I've used distilled water and white vinegar trying to keep it from creating mold. However it's starting to grow a white or very pale looking algee. I've thought about adding maybe bleach, chlorine, or alcohol to the mix, but I'm afraid of what it may do tot he submersable pump and tubes, as well as the interior of the spindle...
    Any thoughts form someone that may know of a good solution? What is everyone else using for their cooling fluid? This is a closed circuit. It's not a cutting fluid. Only a cooling fluid for the spindle of my cnc router.
    Thanks for any input you can share.
    Todd
    www.ToddCreatedWood.com
    May 2008
    142
    Hi
    I just use radiator coolant , my clear tube will slightly discolor to white after 6 months.
    Cheers. Michael
    Feb 2009
    6028
    We use dowtherm or dowfrost in all our water cooled spindles.
    Oct 2011
    I just looked into the Dowtherm and Dowfrost products. The information they have on all the tech sheets is great, but they don't say what the concentration is being mixed with. I assume it's water...? I also looked into where it may be sold, but am not finding much info on re-sellers. Where do you buy your Dow products from?
    Oct 2011
    Wow, I just looked further into that stuff, and it's pretty toxic. There are lots of warning about it's handling and disposing of. I was hoping to find something a little more bio friendly. And a bit less expensive too. It looks to be about 80 bucks for a gallon. Unless that would last me a few years. I don't want to flush so much chemical so often, producing something not easily disposed of...
    Feb 2009
    6028
    We mix at anywhere from 15 to 20 percent with water. When mixed correctly, we probably run it 5 years before changing. Even std antifreeze has all those warnings. Hell, even wd 40 does! The stuff does stay very stable with no growth, and I see it in plastic, brass, and stainless lines without issues. Most of the builders of our precision machines require one or the other. The other cooled spindles are generally velocite 6 light oil.
    Jan 2011
    Adding a small amount of iodine to water will quite effectively keep it from growing anything.
    Feb 2009
    6028
    Have you tried to buy iodine lately?
    http://www.deadiversion.usdoj.gov/fe...007/fr0702.htm
    Jan 2011
    Those restrictions are, I believe, in relation to crystal iodine. You should still be able to buy liquid iodine at your local drug store. Also, I'm in Canada so we don't have that crazy rule here
    The linked restriction is terribly pointless as you can easily make crystal iodine. Make magazine did a video at [ame=http://www.youtube.com/watch?v=CLhwkFKLdPA]Weekend Project: How to Make Iodine - YouTube[/ame] covering the conversion.
    Again though you just need the easy to get liquid version to keep water from going funky.
    Feb 2009
    6028
    That's the problem, even the guy that makes the liquid iodine for campers just got shut down. Damn meth heads!
    Oct 2011
    5 years? at only 20% of 3 gallons, that's not bad. I don't see a lot of retailers though. Do you buy it directly from Dow?
    Oct 2011
    I called Dow today. They were not interested in making suggestions. Seems like the chemicals they sell are so costic that they don't' mix well with lots of materials... The girl I spoke with refused to make any suggestions without knowing the precise 100% breakdown of materials in the circuit of tubes and pumps used in my system.
    I was able to find the manufacturer's number for the submersible pump though. When I called them to ask about what kinds of chemicals are safe to run through their pump. He explained I could run the following Alcohols without harming the internal seals or parts that make up the pump works.
    Amyl
    Butyl
    Ethyl
    Hexyl
    Methyl
    Octyl
    Propyl
    However others would slowly degrade parts and seals... The Tech at Frankllin suggested about a 20% mix to keep things from growing in the water. I'm using a Franklin Electric- Lil' Giant Pump.
    Mar 2006
    7
    I am From Texas and there is too much Calcium in our water and I am thinking of using Prestone 50/50 mix. It good in my truck. What do you think of this?
    May 2010
    313
    Quote Originally Posted by hewittrj78218 View Post
    I think its smart.
    John
  1. Home Made internal spindle stop!
    By widgitmaster in forum Mini Lathe
    Last Post: 08-13-2016, 10:46 PM
  2. Multiple tapped holes on NC, tapping fluid, or is coolant ok?
    By Brian FRF in forum MetalWork Discussion
    Last Post: 12-30-2009, 12:21 AM
  3. SS 304 sheets milling dry or with fluid coolant mist
    By Vincent82 in forum MetalWork Discussion
    Last Post: 11-18-2007, 05:40 AM
  4. CNC spindle and fluid control
    By replicapro in forum CNC Machine Related Electronics
    Last Post: 06-22-2004, 07:37 PM
