588,208 active members*
4,388 visitors online*
    Dec 2007
    71
    Should my motors make noise?
    When i use one power supply (24v @ 8a switching power supply) The motors dont make any noise when they are moving or sitting still. But, when I use a different power supply (32v @ 0-10a probably switching too, dont know) the motors humm and whine when sitting or moving. Is this normal or not?
    4826
    The one turning the spindle should cause a noise. Noise = $$
    I've had an old mill with Bandit cnc that used to make a rather irritating high-pitched whine from some relatively low khz switching supplies. So you may have to compare the switching frequencies of the two supplies.
    Dec 2007
    71
    does it make any sense that it ran a little smoother that way?
  1. Can i make my own Larger DC Servo Motors?
    By higgrobot in forum Servo Motors / Drives
    Last Post: 04-05-2010, 12:04 AM
  2. So Much Noise
    By camcam in forum Open Source CNC Machine Designs
    Last Post: 04-15-2008, 03:39 PM
  3. Replies: 2
    Last Post: 06-03-2007, 02:21 PM
  4. Motors make sound but no movement
    By WarrenW in forum Mach Software (ArtSoft software)
    Last Post: 12-21-2005, 05:05 AM
