588,246 active members*
4,220 visitors online*
Results 1 to 20 of 20
    Mar 2014
    1133
    BT30 spindle belt is terribly loud.
    I'm using T5 belt and pulley to drive my BT30 spindle. That belt is very loud over 1000RPM.
    So I want to change but what is the best timing belt for max 6000RPM? Any thoughts on 5M belt?
    15362
    Re: BT30 spindle belt is terribly loud.
    Quote Originally Posted by Azalin View Post
    Any Trapezoidal tooth Timing Belts will all be noisy
    Here is what all the Timing Belts are and which is best, GT2 or GT3 is improved version of the GT2, is by far the best Timing Belts on the market, if you are not doing rigid tapping then you should be using a Poly-V-Belt around 10 or 12 groove J type would be best, a poly-V-Belt can be used for rigid tapping, if it is correctly tensioned and not over loaded, a Poly-V Belt is almost silent.
    Mactec54
    Mar 2014
    1133
    Well, spindle motor is an AC servo but honestly I don't think I'll ever do rigid tapping.
    I'll take your advice and switch to poly-v belt.
    Thanks Mactec54.
    15362
    Thanks Mactec54.
    What is the Hp of the motor ???
    You can do thread mill if you wanted to without any problems. A lot of builders make this mistake, by using Timing Belts, when they have no need for them, I always use the Poly-V-Belt for spindle builds.
    Here is one I did recently, this is 2:1 10 Rib J series and has a 3 Hp motor driving it, You can make your own Pulleys.
    Mactec54
    Mar 2014
    1133
    Motor is 1.3kw, according to google that is equal to 1.74hp
    15362
    Yes that is about right for 1.3Kw.
    Did you have it 1:1 or have it geared up to get the 6,000 RPM.
    Mactec54
    Mar 2014
    1133
    1:1 pulleys
    Sent from my MI 5s Plus using Tapatalk
    Jan 2018
    1516
    Nice job.
    I can only get a poxy 4 rib J series on mine so can't go too mad with power.
    If I can claw back some money from the machine build. I'll be looking into constructing a whole new head piece for it to house a BT30 spindle and bring the spindle center forward a little to gain more throat depth upto 205mm which atm is 185mm.
    The Y axis travel itself is already extended to 203mm from 180mm when the conversion was done
    (PM25 type machine)
    15362
    Quote Originally Posted by dazp1976 View Post
    Nice job.
    (PM25 type machine)
    Depends on the Hp of the motor and if there is a ratio involved J-4 Rib would not have a very high Hp rating
    Mactec54
    15362
    1:1 pulleys
    Then a 3" or 4" diameter pulley would be Ideal, Belt rap-around contact, with the pulley is important, a J-7 Rib would do the job, for that motor Hp, a J-10 would be over kill, but not a problem if you went with a 10 Rib.
    Mactec54
    Mar 2014
    1133
    hmm. I'm limited to 60mm on the pulley. Will that be a problem?
    15362
    Then go with the 10 Rib-J profile and you will be ok, just go as big as you can fit.
    Mactec54
    Mar 2014
    1133
    Finally had the time to get the belt. I'll cut the pulleys this weekend.
    15362
    That belt looks wider than 10 Rib
    Mactec54
    Mar 2014
    1133
    One rib is 2.34mm so it is very wide. I'll probably cut some to make it 20mm.
    Mar 2014
    1133
    My first try. PJ profile, cutter angle is 40 degrees, 2,34mm distance, 2.06mm groove depth. However I feel like I need to go deeper. What do you think?
    Attached Thumbnails Attached Thumbnails IMG_20211107_222444.jpg   IMG_20211107_214008_HHT.jpg
    15362
    Should go all the way in, when machined, it needs a radius on the top and bottom like these spec's
    Attached Thumbnails Attached Thumbnails Poly-V-Belt Pulley Tec.PNG   Poly-V-Belt Pulley Tec-2.PNG
    Mactec54
    Mar 2014
    1133
    Made a new one but with 0.2mm top radius. Fits perfect. However when I have 2.06mm groove depth then there is a space under the belt. Is this ok?
    Mar 2014
    1133
    Edit: I think the space is because I tested it with the belt grooves faced outside so the grooves are shrinked a bit. The space is much smaller when I test with the grooves are facing inside.
    15362
    Yes it should have a small space at the bottom of the groove this is so the Belt can get it's max grip on the sides, if the ribs hit the bottom then it will slip.
    Something like 1.8mm would be the minimum depth.
    Mactec54
  1. BT30 spindle belt is terribly loud.
    By Azalin in forum CNC "do-it-yourself"
    Last Post: 10-25-2021, 11:35 AM
  2. ATC Spindle Assembly using a Chinese BT30 Spindle Cartridge
    By yezard in forum Uncategorised MetalWorking Machines
    Last Post: 10-16-2020, 08:31 PM
  3. Replies: 1
    Last Post: 04-14-2017, 06:59 AM
  4. Spindle popping/clicking loud on tool change!
    By dbcooper14 in forum Haas Mills
    Last Post: 03-21-2014, 11:57 PM
  5. Loud Spindle Bearings
    By nuclear in forum Novakon
    Last Post: 02-07-2010, 04:56 AM
