587,997 active members*
2,882 visitors online*
Results 1 to 6 of 6
    Aug 2008
    61
    Electrical interference (Plasma Table)
    How can I prevent my plasma cutter from freaking out my electronics? My table starts cutting and then the mouse on the computer blinks off and on and then the axis motors start going nuts. It does not happen if I am not running the torch.
    24220
    Most likely a grounding/common bonding problem.
    Al.
    Albert E.
    Jan 2008
    2247
    How about some details about you cnc machine, and info about your plasma such as make model. There are hndreds of thousands of cnc's running with plasma.....the succesful ones use adequate filtering of inputs and outputs, isolation of the plasma torch leads from other cables, and proper grounding and shielding techniques for the machine and for control cables.
    Jim
    Aug 2008
    61
    Its a homebuilt table with probotix drivers and controller. I think it may have been that I was attaching the ground to the table and not the material. I attached it directly to the material and it has improved. It still freaks out my optical mouse but the motors did not act up.
    Jan 2008
    2247
    And your plasma system make and model? Is it high frequency start? Is it an inverter based unit?
    Jim
    Do verify if you have copper ground properly embedded under 10 feet ground for best performance. We still need your plasma brand & models.
    Non High Frequency Start Plasma Brand such as Hypertherm, Thermadyne & Kaliburn will have very rare chances of freaking out your electronics.
    High Frequency Start Plasma Brand such as China Plasma cutters, Lincoln, etc. uses the old technology to ignite plasma, alot of strong noises will cause your electronics to freak out, as well as crashing your PC. You might even experience Blue Screen Of Death or sudden restart of PC.
    RobotshopCNC Malaysia, Offering Robotic Plasma Cutting CNC, Robotic Flame Cutting CNC.
  1. Help - Get interference from Plasma on my PC
    By nicjac in forum Waterjet General Topics
    Last Post: 03-02-2021, 08:42 AM
  2. Precision Plasma LLC 5' x 5' CNC Plasma Table
    By rchacich in forum News Announcements
    Last Post: 11-10-2009, 05:08 PM
  3. interference from plasma cable
    By calthaus in forum Waterjet General Topics
    Last Post: 04-18-2007, 05:33 PM
  4. Electrical Interference
    By Scratch in forum Waterjet General Topics
    Last Post: 01-13-2007, 05:49 PM
  5. Looking to buy a NEW Cnc plasma table
    By Perp in forum Waterjet General Topics
    Last Post: 09-21-2006, 04:50 PM
