587,227 active members*
3,793 visitors online*
Results 1 to 11 of 11
    Aug 2005
    9
    RFQ Intake manifold Flange Aluminum
    Hello,
    I lam looking for a price for an intake manifold flange in 1/4" aluminum. Piece will be about 4" wide x 1 1/2' long with 4 intake holes and bolt holes. I can provide a cad file.
    Kevin
    Mar 2006
    69
    Need more info please. Qty, timeframe, Cad dwg, tolerances, finishes.
    Apr 2005
    86
    Same here, more info. needed
    Mar 2007
    67
    Same here.
    *** I PM'd you to e-mail me drawings, I didn't get a response, is this RFQ closed?
    Aug 2005
    9
    Found the manifold commercialy
    however I will still need adapters.
    Qty: 4
    Tolerances...... I am not sure it is for an automotive intake so I am thinking .1mm but those of you who know better may be able to advise me on this. Pics enclosed.
    Time frame no immediate rush.
    Jun 2006
    24
    Hello I just sent you a PM for quote
    Jan 2007
    18
    Quote Originally Posted by SouthForkSam View Post
    Qty: 4
    Your drawing only shows 2 bolt holes If this is correct then I could do the job for about $85.00 plus shipping. Thats each
    Mar 2005
    140
    Looks like you might be making a ITB set up although I could be wrong.
    To bring the price of the machining down you might just want to have the plate with the holes made, and then weld on the tube. This will drastically reduce to cost of materials and machining time. If you are not quite clear on what i mean pm me and I'll try to explain it better.
    Aug 2005
    9
    Correct this is for an ITB setup for a 2.3l duratec using gsxr throttle bodies.
    Quote Originally Posted by levelzero View Post
    I can purchase DCOE style aluminum flanges for $32.00 ea (need 2) + s&h. So far the lowest quoted price is very competitive vs buying 2 sets of flanges and paying someone to tig weld the tubes onto the flanges, as I only mig weld and IMO the bead from mig welding the tubes onto the flange would be rather large and unattractive, I estimate about $50.00 to have someone tig weld tubes onto the flanges. I think the labor costs of welding the tubes to the flanges will be similar to what it will cost me to have these tubes machined (as per my lowest bid so far).
    Mar 2005
    140
    Yeah that flanges shouldn't really cost you more then $12-$18 each depending on thickness. Welding is one of those things where if you have a friend or know someone it can be done for a case of beer. If you can mig aluminium, then it's a simple matter of making a vgroove in the flange/runner and some quick finishing with air tools to smooth it all out. Although thats rather labour intensive. If you are getting quotes that are that competative then I can see why you'd want to go that way
    If you have an idea you need engineered or manufactured wether it's a rapid prototype or a full parts run, check us out www.spencercadcam.com We offer full engineering capabilities, design work, CNC programming, and manufacturing. Our prices are very cheap because we want your business, were interested in helping you... not breaking your bank. Contact us through our website if you have any questions.
  1. RFQ: 1/4" Black G10 Intake Manifold Spacer
    By Aaron92SE in forum Employment Opportunity
    Last Post: 01-30-2007, 06:09 AM
  2. Solidworks intake manifold design problem
    By Paul G. Swartz in forum Solidworks
    Last Post: 10-05-2006, 10:52 PM
  3. Bellmouth air intake metal spinning
    By smoregrava in forum MetalWork Discussion
    Last Post: 04-07-2006, 02:21 PM
  4. How Can I Deburr A Manifold?
    By lerman in forum MetalWork Discussion
    Last Post: 08-02-2005, 03:35 PM
  5. machining a manifold
    By MBG in forum MetalWork Discussion
    Last Post: 04-08-2005, 06:41 PM
