These can be obtained from Digi-Key and Newark. The pins do not come separate and crimp on, they require the hand tool that pushes the conductor down into the pins which cut the insulation and make the contact. They plug into printed circuit mounted post type headers. The hand tool is relatively cheap compared to some Amp tools, they come in various terminal spacings, so make sure you get the right tool.
Al
Albert E.
