588,648 active members*
6,378 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Grizzly 12x36 G4003 lathe and tool post grinding
Results 1 to 1 of 1
    Jul 2010
    Hello all. Newie to the forum here.
    I restore antique Harleys 1940-1962. Welder by trade, self taught machinist.
    I bought a new Grizzly lathe in 1999 and have been using it every day since.
    I needed a few special size crankpins made, really simple actually (see pic).
    I emailed a handful of companies. Most told me to get lost or didn't even reply back. One place told me that they would make them for SEVERAL HUNDRED DOLLARS EACH !!!!!! I have a nice digital Paragon heat treating oven, decided to use D-2 Tool steel for it's high hardness and wear resistance. I roughed out the pins, leaving about .015" on all surfaces. I scored a real good deal a while back on eBay. A real nice TheMac J-3 tool post grinder for $150 !!! I have one problem now. I have never used a tool post grinder before. I machined a T nut and have it where it bolts right on the lathe now. I would like to hear anyones opinion on how to go about grinding these pins, i.e.; What can I use to hold the pins, what grade stone, which direction the grinder should run in relationship to teh chuck, wet, mist or no, how much of a cut to take per pass, how to lock down the cross slide so it doesn't move from vibration,etc,etc>
    Anyone?
  1. lifting a 12x36 lathe
    By casta-baga in forum MetalWork Discussion
    Last Post: 12-12-2009, 07:00 PM
  2. is there downlaodable manual for Atlas 12x36 lathe?
    By Goldhunter_2 in forum MetalWork Discussion
    Last Post: 11-26-2009, 06:32 PM
  3. Tool Grinding Literature Needs
    By mc_n_g in forum Toolgrinding / Toolgrinding Machines
    Last Post: 04-03-2009, 05:28 AM
  4. Any opinions on the Grizzly g4016 lathe or other Grizzly lathes?
    By DublD in forum Uncategorised MetalWorking Machines
    Last Post: 11-26-2006, 07:23 PM
  5. Grinding tool bits
    By cncadmin in forum DNC Problems and Solutions
    Last Post: 08-16-2003, 03:06 AM
