588,114 active members*
4,862 visitors online*
    Oct 2006
    25
    Redsail Laser Help...
    Hello Guys
    In october, I purchased a 40watt laser unit from Redsail laser in Ca. The machine is EXCELLENT for cutting acrylic using a plotter file BUT when I go to etch a BMP or JPG file, the machine etches the pic with an "italic" appearance It prints exactly like printing an italic font or something. The picture seems to have a drift to it. No matter how many lines I print or how detailed the pic is, it always comes out with the italic look. If I etch a plotter file, it comes out much better with a slight stagger in small areas. I've checked the belt tensions thinking this was the culprit but to no avail... Has anyone with a laser machine experienced this problem?
    Thanks in advance!
    Brenon
    weird, i had the same problem before but with Solustan Software,
    the problem is the polarity that the motor driver is expecting on pulses, you are loosing 1 step per each direction change.
    Eduardo
    Sep 2011
    I think the problem is the Parameter setting, you need adjust the parameter
  1. redsail laser RS6090C
    By VJK in forum Redsail Laser
    Last Post: 06-04-2011, 06:38 AM
  2. Converting a laser printer into a 3d laser printer
    By João Carimo in forum Uncategorised MetalWorking Machines
    Last Post: 04-30-2011, 09:56 PM
  3. Redsail 3040A laser engraving machine.
    By diarmaid in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-05-2007, 08:28 AM
  4. HP Laser Jet II/III - RPM?
    By Rance in forum DIY CNC Router Table Machines
    Last Post: 01-10-2007, 01:20 PM
  5. Laser in x3?
    By replicapro in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-22-2006, 07:20 PM
