588,483 active members*
4,921 visitors online*
    Oct 2006
    60
    Thin head bolt
    I am looking for 5/16-18 grade 8 x .625 long hex bolts that have a reduced head thickness. 3/16 thk would be perfect. I surfed around on the internet with no luck. I could machine the head however that would add too much cost and I would have to replate them. This is for a production assembly that requires 12 pieces per unit. If you know of a place could you let me know please,
    Thanks.
    Jan 2006
    2985
    You need to surf in the right place!
    Matt
  1. Cutting 0.5mm wide slot in stainless bolt head
    By greybeard in forum Material Machining Solutions
    Last Post: 06-18-2012, 05:28 PM
  2. IH Head ways head lose issue
    By Rich05 in forum Charter Oak Automation Support Forum
    Last Post: 03-15-2011, 06:06 PM
  3. Correct Loctite for locking bolt head not thread?
    By Zathras in forum Mechanical Calculations/Engineering Design
    Last Post: 07-14-2010, 01:23 PM
  4. Cutting off head of hardened steel bolt?
    By shiffrin in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 09-01-2009, 08:15 PM
  5. Where to buy metric socket Allen head bolt/screws Hex .7mm & .9mm?
    By megablab in forum MetalWork Discussion
    Last Post: 08-11-2009, 01:57 PM
