587,687 active members*
3,649 visitors online*
    Apr 2007
    Post Processor editing
    I'am trying to learn how to edit post processors ,and I was hoping sombody
    could help me get me started in the right direction .
    I find it easier to edit an nc program when the sequence #'s are only on the retract lines .I also find it more comfortable while using commands like G0T0 .
    I would also like to move the (M3 S000) line after positioning the spindle .
    T1 M6;
    G0 G98 G54 X Y ;
    G43 Z4. H1 M08;
    M3 S3500
    N100 G0 Z4. ;
    X Y;
    G01 Z Feed plane;
    OR
    N100
    G0 Z4. ;
    Mar 2007
    What CAM software do you use?
    I use UG Postbuilder and these changes you are speaking of
    are quite simple through this program
    Sep 2006
    340
    Wink Post processor or POST?
    The post processor makes the post. Your cam program will contain the P.processor. To edit the post you can use note pad... Or a program like NCPlot...
    Line#'s can be added in the P.processor, also you can order the stuff like spendal.. Although I would start my cutter before makeing a move just in case of an error.
    Good luck!!!
    Hey check out my website...www.cravenoriginal.com
    Thanks Marc
  1. Editing post with Compost
    By rfstar in forum GibbsCAM
    Last Post: 08-30-2019, 07:31 PM
  2. camworks 2007 post processor editing
    By clt1969 in forum Solidworks
    Last Post: 10-03-2006, 03:16 PM
  3. Post Editing
    By jybute in forum GibbsCAM
    Last Post: 09-16-2006, 10:44 PM
  4. editing post processors
    By delbert in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-23-2006, 12:16 AM
