SurfCAM 5.2
Can someone walk me thru programming a pocket that is open at both ends?
My pc is 8" long x 3" wide x .250" thk
I'm trying to mill a "pocket" open at both ends 1.55 wide .070" deep with a
.500" endmill.
I want the cutter to mill beyond the ends of the pc.
I can get the pocket to work without milling past the ends, but when
I change the ends to material instead of part the tool path looks crazy.
It cut a couple of passes thru the center, then jumps to the outside for a pass.
Thank you.
