588,286 active members*
4,619 visitors online*
    Jul 2010
    Autocad to Mach3 problem with arcs
    We about to build a new CNC lathe similar to this one. [nomedia="http://www.youtube.com/watch?v=wnzyZLROtSo"]YouTube- The CentauroT90 CNC AUTOMATIC COPY LATHE DEMO VIDEO for bats[/nomedia] Im looking into the CNC side of it at the moment. I have a demo copy of Mach3 Turn, Lazy Cam, Autocad 2000i and solid works 2004. I am writing the programs in autocad then exporting as a .dxf to lazy cam which converts them to .tap from there I load them into mach3. When i write programs which are made up of straight lines everything is ok and mach3 simulates it correctly. However as soon as i try to get it to machine a curve it all goes bad. The drawing in Autocad looks like this:
    then when i upload it to lazy cam then to mach3 it end up like this When I draw a straight line drawing it looks like this in Mach3 Im not sure what im doing wrong, i just cant seem so be able to simulate a arc. Any help would be greatly appreciated.
    Lachie G
    Jul 2010
    Thanks a lot for that, i have installed it but when i try to upload my .dxf files into it i get an error "Warning, no appropiate turning profile was found." That happens when i try to upload a .dxf file which has curves. When i import a .dxf file with no curves it opens fine im just unsure on how to export as a .tap file for Mach3.
    Thanks a heap,
    Lachie G
    See Appendices B and C in the manual.
    http://www.machsupport.com/forum/ind...1.new.html#new
  1. Huge Problem with Turning Arcs HELP
    By Cartierusm in forum Dolphin CAD/CAM
    Last Post: 06-11-2009, 01:40 AM
  2. Load Mach3 point clouds into AutoCAD
    By ger21 in forum Autodesk
    Last Post: 03-04-2007, 09:31 PM
  3. Fanuc 10M feed problem in arcs
    By AMEG CNC in forum Fanuc
    Last Post: 02-07-2007, 12:58 PM
  4. lines-arcs vs spline problem
    By metlcutr55 in forum Uncategorised CAM Discussion
    Last Post: 07-07-2006, 04:16 PM
  5. AutoCad To Mach2 massive arcs circle. dont know what to do
    By bdesh123 in forum Mach Software (ArtSoft software)
    Last Post: 04-13-2005, 01:38 AM
