our plamsa table was running really great but now it will cut one nice piece and the next one same g-code does'nt cut correctly . We purchased this table in 2016 from a guy named andy from hesperia he seamed ligit he came to our shop set everything up showed us how to use it . he disappeared . something is not set correctly i will up load some photos of the cuts . I have a hypertherm 45 plamsa cutter and a hypertherm 45 interface cable so i can use my hand held tortch on my table . mach 3 seams to run fine with no plasma tourch on . i can cut a amazing piece then it all goes down hill . the first pic is perfectly cut then the others are trashed i also uploded a pic of my table if you need more pics i will upload i really need help i had a guy come recommended our welding supplie place $125 per hour and the only thing he did was hook up my interface cable thank you if you need more info i will give it to you thank you so much... kelly
