Hi guys,
I have been in the cnc business for over 25 years using machines as AXYZ, EXact 51, PACER K, and currently using a HAAS, all running from cadcam programs like alphacam or there own toolpath software supplied with the machine.
I recently purchaced my own machine for working on same projects at home and due to money shortages was only able to purchase a TONSEN TS3040C-H80 from FLEEBAY, it came with artsoft and mach 3 software, artsoft I have worked with before many, many years ago, mach3 is being a pain in my arse but Im working on it.
Anyhow, My problems is I need to sort out some limit switchs and a tool zero setter which will help with my use of MACH3.
I have researched the net but I can not find out anything about my breakout board and where to make the connections for my switches.
The pictures below show the type of control box that came with the machine, and a pic of the breakout board inside,
If any body here has the technical know how that could help me, could you copy and draw on the pic where I need to make the right connections for me to get started. I must add I no nothing about electrics but can quite happilly solder if shown what, where and how.
Many thanks.......
