588,551 active members*
5,531 visitors online*
    2932
    Help for programming NPT threads.
    I've seen enough questions up here about programming NPT threads that I thought maybe I could do something help.
    This little program will create code for Fanuc (2 and 1 line), Yasnac, and Haas G76 cycles. It's beta software, so if you use it, BE CAREFUL... NO GUARANTEES!
    Let me know if it works, doesn't work, helps, doesn't help, what it does wrong, what it does right. All comments and suggestions are welcome.
    Thanks for your time.
    Attached Files Attached Files
    927
    Thanks I'll give it a run..
    Feb 2006
    992
    Thanks, nice tool ....
    The best way to learn is trial error.
    Jun 2005
    232
    Thank you very much .Great program
    Tim
  1. NPT Threads
    By TGSTP in forum Fanuc
    Last Post: 10-05-2008, 08:06 AM
  2. NPT Threads
    By naytep in forum GibbsCAM
    Last Post: 07-29-2008, 02:29 PM
  3. Cam Programming On ID 1/2-14 NPT Threads
    By Josh-PTP in forum Uncategorised CAM Discussion
    Last Post: 02-28-2007, 01:10 AM
  4. Need help with threads
    By Turk88 in forum MetalWork Discussion
    Last Post: 07-27-2006, 07:35 PM
