My Redsail x700 doing 2 problem 1st: Laser tube thorugh out the laser continue and 2nd: X axis is not working i m in trouble please help me now how to solve this problem ..![]()
X-axis... Check the stepper amplifier to ensure it has power. Make sure the wires are connected properly from amplifier to the motor. Make sure wires are connected from controller to the amplifier.
Does the motor hold in place strong?
When telling x motor to move, does it jitter in place?
Sorry.. I didn't really understand the first problem of yours. Can you explain better?
Ray
i have checked many times wires and connection they are perfect ,, Actually X axis is main problem when i push right key X axis is going to left sight and when i push left key X axis not moving to anywhere and second problem is that the laser tube has been directed means when i on the laser machine laser works automatic its through laser continue ,, when i give output then laser should work but here laser is continue throughing without any output ,,,
