587,974 active members*
4,460 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Memory Expansion CNC 88
Page 1 of 2 12
Results 1 to 20 of 24
    Feb 2005
    58
    Cool Memory Expansion CNC 88
    I have a '91 4020 {cnc88} and I'm trying to max the memory in the control. A call to Fadal pointed me towards a REM 93 (128k) Aadd-on card for my existing memory board (1400-2a w/ a 1810-0 plug in card).
    Fadal tried to convince me I'll never find what I need and offered me a control upgrade for @ $3,500.00. I'd appreciate and guidance to help me find this item.
    Attached pic's show my existing card and the plug-in card
    Bill
    Feb 2005
    58
    Pic's of the boards
    Feb 2005
    58
    pic's
    having a hassle getting the pic's up
    Jan 2004
    3154
    I have givin up on this myself.
    my machine is a few years newer than yours (still DC though) and they tell me I can get the mem upgrade, it is approx $5g CDN plus installation. All this so I can have half the memory of my pocket calculater? WTF. Definately not worth it IMO.
    If I absolutely had to run from my machine control I would upgrade the whole control system.
    I currently DNC most of my programs, and if I have some production to do I just keep tweaking the code to get it down to the 2000 (approx) lines that the 88HS will handle, if possible.
    www.integratedmechanical.ca
    Aug 2003
    812
    Call CNCpros.
    http://www.cncpros.net/
    They will be able to get it.
    Feb 2005
    58
    CNCPros sent me to fadal
    darebee, what software you DNC with, I'm running Gibbs
    Jan 2004
    3154
    I DNC with "XPert DNC"
    I used NCNet lite once and then I got my VisualMill 5 upgrade, which had added XPert DNC to the software package.
    I feed the machine from a laptop.
    Your machine maybe has the built in PC beside the control?
    I know they all came packaged from Fadal with Gibbs.
    Wait a minute your machine is too old to have that control setup.
    Aug 2003
    812
    I have a 1460-2a with 422k on it. Will that fit?
    Feb 2005
    58
    422k?
    I will need to seek further info. Sounds like what I'm looking or. I don't know the actual amt. I curently have in the sys. now, but whatever was installed in the orig. set up is what I have. Do you know for a fact if yours will plug in and perform with out any issues? I appreciate your help.
    [email protected]
    Aug 2003
    812
    Let me e-mail you a pic, you can tell me if it looks like it will fit.
    I took it off when I switched my -4 boards to a -5. I eneded up with a 4 meg memory card and this 422 expansion card was a left over. I was just out cleaning my garage cabinets and ran across all of these boards I had and this one reminded me you were looking.
    It was taken off my machine in working condition about 6-8 months ago, so it should be fine, I just don't know if it will fit your system card.
    Belay that let me see if I can just post a pic or two here....if not I'll e-mail them to you...
    hang on a sec....
    Aug 2003
    812
    here
    Attached Thumbnails Attached Thumbnails board 001.jpg   board 002.jpg   board 003.jpg
    Feb 2005
    58
    I have the same (4160-2) plug in here on my desk, problem is (see 2 pic's on 1st page) my card only supports the 4 chip plug in as shown. The card FADAL told me I need is a REM 93 (128k). I never seen one but it's what my control will accept. Did that board come from a '94 machine or newer?
    thanks for you effort
    Aug 2003
    812
    Oh, duh, I totally missed those pics. I see the plugs are different. I just did not look close and assumed you had those plugs that are spaced wide.
    Yea it came off of a 95'.
    I just looked through Fadals site at the online parts order, I don't see that PCB listed.
    Best bet is e-bay I guess if CNC pros did not have it.....cross the fingers maybe someone else will see this post and have your part.
    Good luck.
    Dave
    Feb 2005
    58
    Thanks Dave...
    Bill
    Jan 2004
    3154
    Bueno
    My mem module in my '94 is the same as yours.
    Feb 2005
    58
    '94 card?
    Are you saying that your card in the '94 is the same as the one in my pic's on the first page?
    Jan 2004
    3154
    Yes
    Mar 2005
    12
    hi, i am a factory trained fadal tech. i have my own service company now.
    your problem is in your cpu. a -2 system was never designed to dnc.
    i have complete -5 systems with 422 expanded memory for 4000.00 canadian
    Feb 2005
    58
    I'm not looking to get that far into this. Ultimatley I'm looking for the R.E.M. 93 card which is the "upgrade" for the -2.
    Jan 2004
    3154
    I don't know if my machine is a -2 are not, but it DNCs perfectly fine IMO.
    BTW where abouts is AMHERSTBURG (compared to Stratford), I am looking for a new (and good) Fadal service tech. also have some other references for service opportunities.
Page 1 of 2 12
  1. Using your CNC Mill as a CNC Lathe
    By lstool in forum Knee Vertical Mills
    Last Post: 06-12-2017, 02:29 PM
  2. Beginners CNC Advice
    By UKRobotics in forum Uncategorised MetalWorking Machines
    Last Post: 10-08-2009, 05:10 PM
  3. The start of a big CNC project...
    Last Post: 09-30-2004, 11:34 PM
  4. Programmable CNC I/O expansion
    By psevin in forum News Announcements
    Last Post: 03-04-2004, 06:49 PM
  5. Programmable CNC I/O expansion
    Last Post: 03-03-2004, 07:13 PM
