586,500 active members*
1,860 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Huanyang GT series settings for modbus
    Apr 2016
    18
    How to test if modbus is communicating wit my vfd model GT-7RG-2
    Aug 2019
    13
    Quote Originally Posted by andyjack38 View Post
    Did you ever get it to work? I'm using the 2.2k 220v gt series. Have followed every instruction on the forums with modbusez and no luck.
    Dec 2003
    24223
    Re: Huanyang GT series settings for modbus
    I am using a RS232 program.RS232 Monitoring Software, RS232 Monitoring Hardware and RS232 Terminal Software with a RS485 adapter to test the interface.
    However you need a PC with a COM port.
    See the Mach plug in from Sebastien Mach3 plugin for Huanyang VFD | Le royaume d'éole
    Al.
    Albert E.
    15362
    Al.
    The GT is a completely different VFD than what that plugin was made for, it's worth a try but you don't need the plugin for the GT series to use Modbus
    Mactec54
  1. Huanyang VFD RS485 / Modbus
    By scotta in forum Phase Converters
    Last Post: 05-15-2022, 03:13 PM
  2. Replies: 4
    Last Post: 06-21-2018, 12:15 AM
  3. Huanyang GT series settings
    By jleonqui in forum Spindles / VFD
    Last Post: 06-15-2017, 01:33 AM
  4. Need help with Mach3 modbus settings with Hitachi WJ200
    By macplus in forum Mach Software (ArtSoft software)
    Last Post: 10-26-2016, 07:40 AM
  5. Replies: 4
    Last Post: 01-27-2013, 06:49 PM
