587,986 active members*
4,770 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > question about hard turning with ceramic inserts
    Apr 2008
    23
    Question question about hard turning with ceramic inserts
    DO YOU USE COOLANT ? OR RUN DRY WITH OUT COOLANT ..? OI am tkaing off arox .015 per pass. surface feed of 300 spindle speed of around 400 rpm .
    Jun 2008
    19
    Run it dry
    Run it dry for best results. The coolant will cause thermal shock and weaken your insert.
    4826
    Yup, dry always. The chip should be red hot, that is when you know you are going fast enough. With that being said, I don't like to overshoot the 'just red' condition too far, as this can shorten tool life unnecessarily. Check that your ceramics are rated to machine the type of material in the condition you are cutting, as a mismatch rapidly leads to tool failure.
    May 2006
    573
    IMO you can easily crank it up. I just turned down a piece of tool steel (not hardend though) 80->20mm. 640rpm, 1.5mm on diameter per pass. I have a load of theses inserts, so wear didnt matter, but i didnt notice any anyway. Just watch out, the chips are razor sharp and burning hot (pretty blue). One landed on my neck causing a nasty nasty burn!
    And as already pointed out. Without coolant. You want the temperature to be steady
  1. Hard Part turning
    By Vaibhav.Shelke in forum Daewoo/Doosan
    Last Post: 10-09-2009, 03:11 AM
  2. Questions about Ceramic Inserts...
    By Crashmaster in forum MetalWork Discussion
    Last Post: 06-11-2007, 11:42 AM
  3. Hard turning
    By Steve@Reliance in forum Material Machining Solutions
    Last Post: 07-31-2006, 06:33 AM
  4. hard turning carbide
    By bonz in forum MetalWork Discussion
    Last Post: 01-21-2005, 06:24 PM
  5. Ceramic Inserts
    By Turbine in forum Community Club House
    Last Post: 09-25-2003, 03:23 AM
