588,662 active members*
4,953 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Are there any big-travel CNC desktops available in UK/Europe?
Results 1 to 16 of 16
    Aug 2006
    1602
    Ideally I'm looking for something about the size and weight of a Tormach 1100 or better still Novakon Torus Pro, but the only off the shelf CNC's I've seen are the much smaller Seig KX1/KX3 and the SYIL X-series.
    I could just about cope with 18" of X and 10" of y-travel, but really 24x12" would be better.
    Cheers.
    Oct 2010
    1189
    Re: Are there any big-travel CNC desktops available in UK/Europe?
    Hi what do you want to cut .. do you need atc ? ...
    Aug 2006
    1602
    I want to cut steel and aluminium - I don't want anything routerish, I want a really meaty mill, preferably CNC out of the box, though I suppose a BF46 Vario + CNC Conversion might be an option.
    An ATC would be nice, but is not essential.
    Cheers.
    Oct 2010
    1189
    Hi i do have a klippfeld f12 which i converted to Cnc which has similar envelope like bf 46 but ,.. It is made in Austria ,.. I will Post the New spashguard i got ,..
    Gesendet von iPad mit Tapatalk
    Jan 2007
    1332
    Quote Originally Posted by digits View Post
    Tormach 1100
    Aug 2006
    1602
    Quote Originally Posted by Don Clement View Post
    Tormach 1100
    I may well end up just importing one myself , but being at least 3,500 miles away from the nearest spare part makes me a bit nervous about spending the $11,400 I reckon it would cost me to import a base machine with no stand or accessories ($1000 shipping + 20% Tax in the UK).
    Given that all the machines start life in China, it seems likely that someone a bit closer to me is already importing/rebadging/supporting them...
    Jun 2006
    3063
    Tormach generally ships spare parts same day, though air express would certainly increase your cost quite a bit. They also have a spare part kit and that might be a good idea to buy along with the mill, especially if your income depends on a functional mill.
    Mike
    Aug 2006
    1602
    TBH I am very tempted by a Tormach - I already have a lot of TTS tooling, but the X-travel is a bit too short for my liking.
    Oct 2010
    1189
    Hi The Mill i use (build Since 40 years in austria no China stuff )
    Has an table 200 x 750 mm travel is 175 x 440 mm
    Z axis around 300 mm (i would have to go down and measure )
    The Tool holder are iso30 ..
    So if you search like i did for a non chinese machine this could be an Option ..
    Aug 2006
    1602
    Quote Originally Posted by Tkamsker View Post
    Thanks - I think that's just a bit smaller travels than the machine I currently have. I may go look at a 'real' Opti BF46 soon - they are not cheap though!
    Oct 2010
    1189
    Do you intend to get an bf46 and cnc it ? I checked the travel it is not that much difference ; )-
    Aug 2006
    1602
    Hmm, the Opti website and user manual disagree slightly - the manual says 520mm in X and 260mm in Y which is significantly larger than your machine IMO. I really would like 200+ mm travel in Y...
    Oct 2010
    1189
    Hi you are right my Bad
    Optimum Maschinen: BF 46 Vario
    But maybe you lose some mm while cnc Ing ...
    Aug 2006
    1602
    Yes, that's possible! I am going to go and see a BF46 at the end of this week - it will be interesting to see where they've added 200kg over the BF30!
    Oct 2010
    1189
    Hi
    you know that because of the sky fire disaster i now really look into "is it possible to have" non china mills ,..
    that is why i also have an eye on that optimum stuff
    The bf46 has is40 as far as i have seen this means the spindle should be massive that adds some kg ,..
    I hope you find your 200kg
    I had an look at cnc and optimum Optimum Machines: M 2LS / M 2LS ADVANCED
    and they have less travel ,..
    (i am glad that my mind did not trick me ) so be sure you don't loos too much at travel ,..
    i did some lifting at weekend with my machine i designed a new kind of splash guard and since weekend the machine is on the new "bed"
    will look like a little bridgeport 412
    thoma s
    Aug 2006
    1602
    I think that M2LS is probably based on the Opti BF20!
    You seem to have to go for very large machines to get much bigger travels once you go to a 'proper VMC' - but unlike most benchtops, they don't seem to have a 2:1 or greater X:Y travel ratio. E.g. this 'mini-mill' XYZ MINI MILL 560 - Vertical Machining Centres and Production Solutions - XYZ Machine Tools has 560x400mm X and Y travels.
    And if you have the room and 3-phase power, not hugely more expensive than the Opti B2LS if you by used : XYZ 560 Mini Mill
  1. Looking for kit in Europe
    By Busch_dk in forum DIY CNC Router Table Machines
    Last Post: 08-20-2013, 08:14 PM
  2. Morntech-europe + Laser tubes delivery to Europe (Belgium)
    By gillespinault in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-16-2013, 05:04 PM
  3. Discuss Desktops and Laptops here!
    By cncadmin in forum Computers / Desktops / Networking
    Last Post: 06-13-2012, 05:50 PM
  4. Lazy Cam not posting Fast Travel as Fast Travel
    By astainless in forum Uncategorised CAM Discussion
    Last Post: 02-24-2010, 09:31 PM
  5. archiving programs on floppies/desktops
    By chipsinpan in forum Milltronics
    Last Post: 01-06-2010, 04:57 AM
