588,357 active members*
7,427 visitors online*
Page 1 of 3 123
Results 1 to 20 of 48
    May 2011
    cncconversionkit.com???
    Has anyone had any experience with this company? any Reviews or thoughts???
    cnc kit, diy router, mini mill, x2, x3, build, milling machine, machines, home made, used, woodwork, make your own, low cost - Taig Ballscrew BF20 Mill milling routing machine machines
    Hello CNC zone , my name is Ethan.I work in steel, doing architectural installations. You can see my site here http://www.midnightmetalworks.com
    I would like to try scaling down my work and so I am interested in buying a small bench top cnc mill for carving wax for jewelry.
    I am considering a taig!!! I am looking for advice on wether this taig would work well for me...
    This page details a taig adapted for a 5th axis:
    Taig mill 5 axis with ball screw - Taig Ballscrew BF20 Mill milling routing machine machines
    indexed 5 Axis Machine
    Included
    Taig mill with ball screw
    Trunnion Table with 2 sherline rotary table
    5 x Gecko g201 cnc driver redy to go
    5 x nema23 270 oz motors
    configurable post-processor
    mach 3 up to 6 axis
    Thanks in advance for your help!
    I have also been considering some other brands so if you have any other ideas I should look at please let me know...
    Ballscrew conversion/5th Axis
    Ethan
    The Taig mill is more than capable as it comes, so there has been a long discussion on the taigtools list as to the advantages 2nd otherwise of ballscrew conversion. I have many customers who do very fine work with the bog standard machine, once they have become used to keeping it 'well tuned'. As for the fifth axis being supplied on the bed of the taig - again, the design of the Taig provides a good amount of clearance over the bed to do that, but providing the fifth asis by simply mounting a second rotary table on the back of the spindle gives a MUCH bigger working foot print.
    Nothing against cncconversions - he is trying to do a good job, but his targets just seem to be wrong at present.
    Lester Caine - G8HFL
    http://medw.co.uk - Home of electronics for the Model Engineer
    May 2007
    767
    Hi Ethan
    Nice sculptures. Suggest you define the size length - width - depth you wish to 'carve'.
    The problem comes when you add extra axis. The extra axis require support bearing structures and motors all of which can eat into the envelope of a 3 axis machine to leave very little room between the cutter and the work. I know this is obvious but adding the fifth axis reduces the total envelope that can be cut considerably.
    As well as a suitable machine you need software that can translate a 3D conceptual computer generated graphic into code to drive the various axis to deliver a the surface as a reproduction of the computer graphic but in solid form.
    The CNC axis motors have to drive the extra mass added by the forth and fifth axis. Acceleration and maximum traverse rates act with the inertia caused by the total mass being moved along with losses due to friction to determine the motor size required. 270 oz inch torque sounds very low. Motors that are too small will stall and wreck the work as the axis become uncoordinated. Motors that are too large can suffer resonance problems. Closed loop servos are much to be preferred where the need is for fast slewing of the part under the cutter.
    I would be suspicious of any source of hardware that makes a point of slagging off their competition and not giving the basis for that comparison. When comparing ball screws be-aware that there are not only different specifications but there are also various ways of minimising the backlash. The drives for the first three axis might be linear and ball screw candidates the extra axis are rotational and will involve rotary not linear motion. There are some weird and wonderful machines with videos on YouTube that employ cantilever leg type construction to get the cutter into position - these machines are large compared to the actual envelope of the work they can do.
    Good luck - Regards - Pat
    PS - IMHO what you might be looking for is a smaller edition of this one http://www.doughtydrive.com/productc.html rather than a conversion job on a small bench top mill/drill.
    Jun 2011
    I looked at your metal art on your website, very nice!
    I called up the guy at cncconversionkit a few days ago to get more info on his ballscrew upgrades. I dont really need ballscrews for what I do, but I love tweaking and upgrading my toys. I think I will buy the kit after some more checks come in. He said he started working on this kit for his son, who is a jeweler, to carve wax. So it might be ideal for what you want to do. Call him up and talk to him.
    One other Taig to look at is here: MicroMill DSLS 3000 Its a taig with servos instead of steppers. Servos are generally thought to be more accurate since they are closed loop.
    Quote Originally Posted by darrellatg View Post
    Correction to that!!!
    The DSLS3000 is still stepper motors. It just adds an encoder to the shaft of the stepper motor and does provide some protection against missing steps but is no more accurate than the standard 2000 model. If anything it is ACTUALLY less accurate unless you run at slower speeds. The main problem with it is that Mach3 does not know that the 'correction' mechanism is working, so if a long move on one axis is still happening when Mach3 changes direction, corners get distorted.
    The idea is good, but being practical, a good bipolar drive setup is a much better 'upgrade' and has to be recommended as a first choice if one is starting out.
    And while I'm still running a DSLS3000 controller on the demo mill here, I know it's quirks which took some time to appreciate. One has enough trouble with the basics of CNC without adding other variables when starting out.
    Quote Originally Posted by domasomajutt View Post
    mine is hooked up right to my tv with out going through a converter
    that would be your best option
    Any chance you can explain what you are talking about?
    May 2007
    767
    Stepper motors when over loaded miss steps and the problem is that once they start to stall feeding extra steps to try and correct is of no practical use. With open loop drives it is essential to have sufficient power (torque) for all circumstances.
    If an encoder is used to check that each step has been made then simply detecting the missed step and adding an extra one is not a viable solution as more power is needed not extra steps.
    Detecting missed step might have use to halt the machine or warn the operator of the malfunction.
    Suggest you ask the vendor DSL for a detailed explanation of how their system works. It is just possible they have had that Eureka moment and found a way out of the lost step quagmire. If so why have they not used linear scales so that the table is driven to the precise position instead of putting a rotary encoder on the motor shaft?
    Power servos with linear scales cost around ten to twenty times the price of a stepper drive and have different motion controller needs.
    Regards - Pat
    Quote Originally Posted by wildwestpat View Post
    Regards - Pat
    Totally correct, which is why Kurt's closed loop approach does not work that way. He is able to adjust the width of the pulse applied, and continues to apply power until the motor moves. This approach actually works very well, and gives a usable reliable speed increase over the identical open loop package. The problem with the system is simply that since the pulse width is varied, following pulses have to be buffered, and as I have already said, Mach3 does not know about that correction process, and so looses position on it's own display. To work well, this approach has to be integrated into Mach3, which is not practical, but it could be handled properly in EMC2 where the encoder output can be used directly by EMC2.
    In practice, replacing the DSLS3000 controller with a good bipolar driver package is currently a lot more practical.
    May 2007
    767
    Hi Lester Thanks for the explanation. With the price of hybrid motors and modern shaped current drives now I know I am not missing out.
    Regards - Pat
    Jul 2009
    205
    Back to the Ballscrew thing;
    Cutting waxes and small camera parts is right along my lines, so this looks good. For years people have talked about how difficult it is to convert a Taig to ballscrew. It seems pretty straightforward and nearly a bolt-on from what I can see, and this conversion kit looks that way too. What am I missing?
    1)Is it really as easy as it looks?, and
    2)What parts is he using to do it? Has anyone who has done it put any details online?
    Apr 2010
    The price for this is just bonkers. I don't get it. The options make no sense either. Both of them look like they want you to send parts over there but the last one is saying that after your Y axis and X axis stuff is received you will get a ballscrew kit sent to you what the heck?
    In either case I don't think this is worth the price of another Taig Mill.
    Jul 2009
    205
    Quote Originally Posted by Rift View Post
    I would agree, which is why I want to know what screws, nuts, and bearing blocks he is using.
    I have a workshop, I can do it myself. Much cheaper as well I would imagine.
    May 2011
    thanks
    Thanks to everyone for their thoughts. I'll let you know how it goes!
    Mar 2012
    12
    Just a friendly warning about this company cnc router machine, cnc kit - Taig Ballscrew BF20 5 axis milling located in Windsor, ON. I placed an order in march 2012, for a Taig machine with ballscrews. I Paid promptly by bank transfer the agreed price of $2,450.00
    After dodging for over a month and offering all kind of excuses ("Taig changed the machine design so the ballscrews no loger fit the new casting", etc...) and promises ("I am working on it", "it will be delivered next week", etc...) the owner [name withold for the moment: I have his real name from the bank, but be aware, he's using all kind of aliases to play hide and seek] of this family (non-registered) company just dropped out of sight, after shipping a geko driver and three Nema 23 stepper motors with cables (worth probably about $500).
    A Small Claim Court in Toronto is currently dealing with this thief. Apparently I am not alone, others are shafted as I'm writing this: eBay Feedback Profile for kurka12 Be warned about this company, they are still advertising this type of machine and conversion kit (and they even rose the price since I ordered)!
    I would point out that Taig HAD stopped shipment of the Mill for a number of months because the company that supplied the Y axis saddle casting went bust just when they needed to order some more. It took a few months to have replacement tooling made for an alternative extrusion, and they made some changes which WOULD affect the way the Y axis ball screw was mounted.
    Doesn't cover the lack of service, but I was waiting for a replacement saddle for a machine over here which was 'a couple of weeks away' for some time. Taig can be a little difficult to get information from and so I can understand why the problem arose.
    That said - I still have to be convinced that the ball screw conversion does actually give any real advantage?
    Dec 2007
    101
    The person shouldn't say he has parts in stock when he doesn't. I originally tried to purchase the ball screw kit from him through ebay. After I used buy it now, he sent a message that he didn't have the parts but he would order them that day. I immediately requested to cancel the transaction. Glad I didn't send payment.
    Mar 2012
    12
    Quote Originally Posted by lsces View Post
    Backlash. I was planning to use the Taig for PCB milling, and for such an application there are two critical issues: table planeity and backlash.
    Backlash can be avoided by closely tuning the machine, but I found that ballscrews are offering a much more reproducible performance, with less trouble in adjusting. Also ballscrews are allowing larger speeds for the same PCB quality.
    Probably for most of other applications the ballscrew improvement is minimal. Meantime, I got a Red Sail chinese machine, threw away the ****ty extrusion table and replaced with a 19"x19" Al casted and machined table and the results are very good. Planning to replace the controller with geko and use Mach3, that's a lot of re-wiring though.
    Jun 2012
    Feb 2007
    456
    I have milled hundreds of PCB on Taigs with no problems. The stock lead screws are quite good, you can adjust the nuts and get down to 0.0005" of backlash without a problem.
    IMHO, in the hobbyist world 'ball screws' are a buzzword, just like 'billet' it to car guys. Just using ball screws does not make a machine more accurate, cheap ball screws are no more accurate (w.r.t. backlash and linearity) than cheap lead screws. A good quality ground ball screw can have very little backlash and very good linearity, both are important when running a larger industrial machine 24/7. For a machine the size of a Taig there is really little benefit. The average user will see a lot more variation in his work coming from tool deflection and wear than from inaccuracies in the lead screws.
    Jeff Birt
    Jul 2009
    205
    Quote Originally Posted by Jeff-Birt View Post
    So very, very true. Ballscrews have some advantages, but accuracy and backlash are actually NOT inherently among them. There are ground ballscrews that cost an order of magnitude or more than rolled ones and and do have this as an advantage, but these machines won't have them. You get just as much backlash, if not more sometimes, out of rolled screws and single-circuit nuts as you do from a set of decent acme screws. What you gain are things like screw efficiency, and lower wear, which is really good if you are running the machine 24/7 in a production environment where regularly wearing them out, and downtime for maintenance, is a big deal. For us, not so much.
    Also very true. Besides, even with backlash, your toolpathing strategy can eliminate it as a problem anyway. I am not talking about just turning on backlash comp (I never do, btw), just smart layout of how and from what directions you cut to minimize or eliminate the effects of backlash.
Page 1 of 3 123
