588,342 active members*
5,336 visitors online*
    Apr 2004
    12
    Mini mill head on a Taig
    Hello all;
    I have a Taig mill, and have been happy with it. But I was thinking of putting a Mini mill head assy from Little Machine Shop on it . I would like the R-8 spindle and would get the belt conversion for it. I do a lot of work on Alum, so I need a higher speed range ( 4000 - 8000 rmp ) . I was also looking at Lathemaster mill, but spindle speed to low, and the miil is kinda big from my Apt.
    Another idea was get the ER-16 spindle and the Sherline dc motor, add flood coolent and be happy ..........
    Thanks guys Mitch .....................
    Jan 2007
    66
    Quote Originally Posted by mcundiff1 View Post
    Hello all;
    I'm a bit puzzled by your approach - I have an X2 (mini-mill) with the belt drive conversion and am looking at a Taig, in part because the maximum speed of the X2 with the belt drive conversion is 4000RPM (not 8000)
    There is an optional motor for the Taig that will take you to 10,000 RPM and, since the Taig is available with an ER-16 spindle, the conversion should be easy - finally, I'm not really certain that the mini-mill spindle bearing will handle 10,000 RPM
    To my mind, the only significant advantage the X2 has over the Taig is the quill control which allows me to use the mill as a drill press with precise work positioning.
    EM
    Feb 2007
    424
    Taig mill, has that speed range depending upon the motor, it you convert to high speed spindle like many have done you can have alot more. You can get the two pole motor, from carter tool I believe, I am sure Nick will see this post. At anyrate that mill is already capable of 10k with the proper motor, trying to put a different heavier head on the mill is just reinventing the wheel.
    It also has the ER16 spindle option which you can order.....
    chris
    Oct 2004
    168
    I bet that the minimill head is even heavier than the Taig head and motor. You will certainly need beefier steppers for Z in that case, and it may place a lot of stress on the z axis (how much does it weigh?)
    The Taig CNC spindle runs at 10K rpm in the top speed range.
    Nick Carter
    Largest resource on the web about Taig lathes and mills
    www.cartertools.com
  1. Home-Brewed CNC Bench Mill Using Siex X2 Mini-Mill Head
    By fignoggle in forum Benchtop Machines
    Last Post: 05-12-2009, 05:11 AM
  2. Coming Down to the Taig Micro Mill or Grizzly Mini Mill.
    By CROSSHATCH in forum Taig Mills / Lathes
    Last Post: 01-23-2009, 06:14 AM
  3. Taig Vs Mini Mill
    By heilcnc in forum Taig Mills / Lathes
    Last Post: 03-09-2006, 04:31 AM
  4. Mini Mill Head Height
    By dropride in forum Benchtop Machines
    Last Post: 12-04-2005, 12:39 AM
  5. More Z travel please, For a Taig Mini Mill
    By MrRage in forum Taig Mills / Lathes
    Last Post: 11-03-2005, 09:46 PM
