Try a sample.
Can you ream a similar part on an existing machine.
If so, measure the supply current before you start cutting, do some cuttng and measure the current.
Subtract idle current from tha largest reading you got.
Multiply that by supply votage, and divide by 746.
That's roughly the horsepower you used, plus whatever losses crept in.
You need at least that much.
If the supply is single phase it is easy. If multiphase, then it gets more complicated than above.
