587,216 active members*
3,101 visitors online*
    Apr 2020
    50
    Question Replacing PSU with higher wattage PSU CO2 Laser
    Hi I have a K40 Laser "700mm Tube" and the PSU just **** it self.
    I can wait 2-4weeks to get one.
    or...
    I can pick up a, what is advertised as a 60W PSU, but the model indicates a 80w "Cloudray MYGJ80W" see attached. for a good price as a quick fix.
    I do not need the same pinouts as old PSU as I have replaced the controller and only use HV side of PSU to run Laser.
    My thoughts where to use the MYGJ80W PSU till I get a 40W replacment to get me out of trouble.
    The Blown 40W PSU Specs: MYJG-40W
    25KV
    20ma
    The quick fix MYGJ-80W
    26KV
    28ma
    My intention is to limit the power on the replacment PSU
    I have searched this with a bit of confusion, have noticed comments like tube is only 10-12ma and start voltages/current and so on.
    cheers.
    Feb 2022
    11
    Re: Replacing PSU with higher wattage PSU CO2 Laser
    Hello , look in to the new power supply , it has a small hole , you can use a small crewdriver flat to adjust the potentiometer/ veriable resistor to the desirable current , if for any reason can not adjust you can send the files from computer SW with lower power and it will work well
    Good luck
    Apr 2020
    50
    Quote Originally Posted by lasersparts View Post
    Good luck
    Cheers
    I was of similar opinion that I can turn down the power to suit the tube, anyway if it stuffs the tube ill have to buy a bigger one
    I have picked her up and it has a small hole with what looks like a smal pot.
    If this does not work I will limit it in the software.
    I will do more of a report late on how I went.
    Apr 2020
    50
    Lightbulb Re: Replacing PSU with higher wattage PSU CO2 Laser
    So far all good, I am back up and operational.
    I will report back if I experiance any problems over time resulting from the higher output PSU.
    Picked up a brand new MYGJ-80W , could not resist when it was for $40 AUD and 5 min up the road from me.
    Thanks to lasersparts reply identifying a max power adjust/set pot accesible from side of PSU enabled me to limit the Max power of the PSU
    I have attached Pics of the PSU and the location of the power level Set/Adjust pot.
    Thie location will change with varying models/brands and some may not have it at all.
    I turned the pot counter clock wise all the way, then I turned it clock wise 2 turns and performed a Laser burst test fire.
    Checking the Laser current power meteriIt read 6 mA.
    I turned the Set/Adjust Pot and test fired untill it was 12mA on Max Power.
    Previously my Power meter was firing at up to 15mA, i noticed some posts sugesting it should be in the 10-12mA.
    What should be the max mA setting for a 40w tube?
    Hope this helps others in the future.
  1. Wiring Chinese GRBL Board to 80W CO2 PSU
    By BergenB in forum Laser Control Software
    Last Post: 08-26-2021, 01:55 PM
  2. Laser Tube CO2 PSU
    By baron_africa in forum Laser Hardware
    Last Post: 10-15-2019, 08:49 PM
  3. Getting dashed lines after replacing 50w Tube & PSU
    By SteveCrisp in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-18-2016, 01:55 PM
  4. CO2 PSU and TUBE ? Can I use a 40w PSU with a 50w tube ?
    By TrickyCNC in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 07-17-2014, 07:36 PM
  5. Questions about an old control/ its psu/ a new psu/ old servos
    By GM1G in forum CNC Machine Related Electronics
    Last Post: 05-26-2012, 08:56 PM
