588,487 active members*
5,462 visitors online*
Thread: Making A CNC
    Feb 2009
    Making A CNC
    Hello people of CNCzone,
    I am making a CNC to cut wood, plastic, some other weak stuff and hopefully aluminum. I'm thinking of possibly making another CNC with it and selling it to my friend so it has to cut what it's made of. What should i use mdf?
    what i need help with most is electronics and software. And i have a cnc lathe in which i can turn some parts that may be necessary for my cnc.
    i don't have any instructions for it. I just found it its an MTI Sm 5110 something like that. I have the thing and it can power on, how do i use it to do cnc work? thanks.
    Feb 2005
    168
    Hi there is a wealth of information on this site and lots of variable options whether a flying gantry or a moving table is whaat you want to build. If you are not certain and have very basic knowledge of CNC try buying the plans from Rockcliffe, they are outstanding and everything is well explained and more importantly produces some very accurate cuts IMHO, I'm sure that everything to do with CNC is all in this forum use the search function and you will find your answers hope this helps.
    Feb 2007
    4553
    Smile
    Please post more information, correct model number and maybe a picture or two.
    Someone may be able to help you once you correctly identify what you have.
    Welcome to the Zone,
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  1. Making a CMM
    By Fish in forum Uncategorised MetalWorking Machines
    Last Post: 09-12-2008, 05:13 PM
  2. jig making
    By DerHammer in forum MetalWork Discussion
    Last Post: 11-19-2007, 06:29 AM
  3. Making M2
    By pekeX in forum MetalWork Discussion
    Last Post: 04-06-2007, 01:47 PM
  4. making an arc
    By keebler303 in forum Bridgeport / Hardinge Mills
    Last Post: 10-15-2006, 07:40 PM
