588,076 active members*
5,021 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > Yaskawa Varispeed 505MT drive will not brake nor reverse
    Jul 2005
    205
    Hi!
    This DC spindle drive stopped reversing and braking but otherwise seems to work ok.
    There are no alarms. I know the main pcb is to blame as it works fine after testing with another borrowed main board.
    This drive gets +-10VDC from the Yasnac 2000B control and should change direction based on the signal polarity.
    I have searched the web and Yaskawa for schematics but no luck so far.
    Does anyone know which components are the usual suspects? I have attached a picture but not sure the max allowed resolution is sufficient.
    The missing electrolytic capacitor in the lower right area had to used for the loaner board.
    Also; this drive has a separate Thyristor Exciter unit for the field which has a shorted NEC 20P6S stud SCR I need to replace. There are no data sheets available and NEC does not have any specs.
    Is there any less obsolete SCR on the market I could use?
    Cheers,
    Andy
    Feb 2016
    116
    Quote Originally Posted by Andy Fritz View Post
    Hi!
    Cheers,
    Andy
    I have a whole set of boards I'll sell you for a really good price, I also have the schematic for the spindle drive. PM me your email and cell number
    Jul 2005
    205
    Quote Originally Posted by Redzilla View Post
    I sent you a pm.
    Feb 2016
    116
    I sent you a pm.
    I didn't get it just text me
    606- 547 - 78six three
    Jul 2005
    205
    Re: Yaskawa Varispeed 505MT drive will not brake nor reverse
    I just sent you a sms with my email.
    Andy
  1. yaskawa varispeed 626vm3.
    By wilko1 in forum Servo Motors / Drives
    Last Post: 10-23-2019, 01:42 AM
  2. anyone have a broken Yaskawa Varispeed 505 drive?
    By acannell in forum Mori Seiki lathes
    Last Post: 11-09-2015, 06:51 AM
  3. yaskawa 626 varispeed
    By george9 in forum DNC Problems and Solutions
    Last Post: 10-15-2010, 12:45 AM
  4. Yaskawa Varispeed 626 MT
    By bradodarb in forum Phase Converters
    Last Post: 04-27-2009, 02:38 PM
  5. Yaskawa Varispeed Spindle Drive component ID
    By rbleth51 in forum CNC Machine Related Electronics
    Last Post: 07-13-2007, 10:18 PM
