588,685 active members*
6,315 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Need direction for electronics purchase
    Mar 2004
    636
    I am currently building my first cnc router. MDF Construction with 30 x 48 x 6" cutting area. I am looking for a package that I could purchase that contains all the steppers, power supply, etc. Basically all the electronic stuff. I can easily build a machine, but know nothing about the electronics. Does something like this exist?
    Dan
    Apr 2004
    100
    Hobbycnc.com
    Stepperworld.com
    Mar 2004
    636
    What to look for in steppers
    Thank you for the above links, but I have a couple of quick questions about the stepper motors. I notice different numbers such as 80 oz/in and 125 oz/in and so on. Up to very large numbers. What does this mean and what should I be looking for for my cnc? It's main use will be cutting mdf and solid wood and maybe parts for my next router (some aluminum).
    Dan
    Jul 2003
    167
    oz/in is a measure of torque. In simplest terms, it is stating that it can move/hold a 125 oz weight on a 1" long lever. Note that there is continuous torque and stall/peak/holding torque. Higher numbers are stronger.
  1. Vertical/Horizontal Bandsaw purchase
    By ChrisJ in forum MetalWork Discussion
    Last Post: 07-21-2007, 02:30 PM
  2. What to Purchase
    By Robin in forum MetalWork Discussion
    Last Post: 02-28-2005, 01:53 PM
  3. motor direction
    By sixpence in forum Mach Software (ArtSoft software)
    Last Post: 12-29-2004, 05:15 AM
  4. running direction problems
    By gv71 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-27-2004, 01:19 PM
  5. z axis direction question.
    By ljoe1969 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-22-2004, 02:53 AM
