587,852 active members*
4,036 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > EMCO Mills > Need help with collet size: PC Mill -30
    Mar 2008
    161
    I want to take my milling to the next step and realize I need some collets to do this.
    Right now I am using a small piece of drilled out and tapped aluminum bar stock to hold my end mills.
    Sometimes it works....sometimes it is ugly.
    The only info I found was from a NZ selling a similar model who said the collets have a 10mm OD.
    Anyone know what kind of collets to use?....or
    Are there measurements I could take of the inside of the spindle where the collet fits in to find out if there is standard type of collet to buy?
    Mar 2008
    161
    Here is a crude cross-section of where the collet would fit in.
    Maybe the included numbers may jog somone's memory about familiar collet sizes.
    ....I hope.
    Thanks for looking
    Mar 2008
    161
    ER11
    I finally ponied up $25 for some an ER11 set. They fit nicely. Now I just need to test their runout.
  1. ER16 Collet Size Problems
    By Bob La Londe in forum Uncategorised MetalWorking Machines
    Last Post: 02-08-2012, 06:24 PM
  2. Wrong collet size with Chinese spindle
    By Georgie in forum CNC Machine Related Electronics
    Last Post: 09-24-2011, 02:40 PM
  3. Replies: 2
    Last Post: 12-31-2008, 05:14 AM
  4. Collet type & Alu mill cutters
    By fotiosanagnosto in forum MetalWork Discussion
    Last Post: 05-19-2007, 07:45 PM
  5. What is this collet size?
    By kong in forum Uncategorised MetalWorking Machines
    Last Post: 06-06-2004, 07:07 PM
