588,457 active members*
5,102 visitors online*
Results 1 to 6 of 6
    Apr 2004
    20
    thk versus thompson
    Maybe im over looking something but i was just wondering what is the big advantage to linear bearings like the ones made by thk versus the pillow block style from thompson? I can see them being more accurate but accurate enough to really compensate for the price difference?
    Nov 2003
    634
    1. You can use a smaller THK slide to get the similar strength as a round way bearing. Check the spec's.
    This helps in certain instances where space is a problem.
    If you use a supported Thomson bearing, it will work just fine.
    For DIY use, its whatever you can find and afford.
    THK Rails have roughly 10x the load rating of a similar diameter round rail. They also last sooooo much longer compared to round.
    Proud owner of a Series II Bridgeport.
    Apr 2004
    20
    Seems to me in most cases the thomson wins as far as my applications are concerned. The wear factor isnt a real big concern to me as replacement can be made pretty easy and done fairly cheap compared to thk. The strength factor might be nice but when weighing the cost to strenght i guess cost wins again in my application.
    If your using supported Thomson shafts, it's no problem. Unsupported can be difficult to keep from flexing.
    For anything but an industrial application or heavy milling, Thomson round rail will work fine.
  1. Grease in my THK bearings/carriages
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 07-07-2008, 04:44 AM
  2. Joining two THK SHS15 rails
    By PEU in forum DIY CNC Router Table Machines
    Last Post: 05-25-2005, 02:16 AM
  3. How close can I space THK rails?
    By bgolash in forum DIY CNC Router Table Machines
    Last Post: 12-31-2004, 06:13 AM
  4. Wrong THK rail - Help!
    Last Post: 07-17-2004, 07:26 PM
  5. Belts versus Direct Drive
    By bsmith in forum DIY CNC Router Table Machines
    Last Post: 06-07-2004, 04:09 AM
