Hello,
I need the wiring schematics for this servo motor:
Simple Servo 524-20-320B
11.3 in-lb @ 3.4 amps
3000 rpm @ 120VAC IN
encoder 2000 PPR Quad
Brake 24VDC @ 1 amp
thanks,
Jorge
Hello,
Brake 24VDC @ 1 amp
thanks,
Jorge
May be same good man help me too. Was searhing here but found only encoder pinout for its or similar (I hope) driver.
Simple Servo 524-20-312-0046
2.8 in-lb @ 1.4 AMP
3000 RPM @ 240 VAC IN
ENCODER 2000 PPR QUAD
How many pole counts at last? Can I count them by rotating shaft and counting hall sensor switches? That was 4 x 2(+ and -) counts.
BLDC or AC? 1.4Amp peak or cont. ? What is for "IN"?
Many thanks for any suggestions.
If you monitor one of the Commutation pulses by turning the shaft slowly, the amount of times the signal goes to 1/rev = count x2 = pole count.
IN = AC supply, which would imply a AC sinusoidal motor, rather than BLDC.
Al.
Albert E.
