587,311 active members*
3,615 visitors online*
Results 1 to 9 of 9
    Jan 2007
    355
    Polyurethane support rails ???
    To make a long story short...
    I'm designing a 48x36 router, stainless steel shafts, linear bearings, etc.
    After pricing aluminum shaft supports, I'm toying with the idea of creating a silicone mold and using polyurethane resin to create the rails at a much lower cost.
    I think it will be strong enough. It will be bolted to the shafts and to a steel frame. It will there simply to keep the shafts from deflecting.
    Has anyone tried this stuff for structural components of a router?
    If it fails, I can always reuse the silicone mold and try my hand at lost wax casting with aluminum
    May 2005
    674
    Way too soft and squishy. Plus it shrinks as it dries.
    Mar 2004
    1661
    Everything is about how much load you will put on the rails, but yes it will work for lighter loads. P-u flex a lot more than alu. If I were you I would go for full length support.
    Regards,
    Sven
    Mar 2004
    1661
    Quote Originally Posted by Zumba View Post
    It will shrink homogeneous.
    May 2003
    792
    Epoxy Granite might work.
    Jan 2007
    355
    Thanks for the input.
    I've seen PU shaft end supports on eBay, thought it might just work for a full length shaft support.
    Anyway, I have about 3 gallons of this stuff, 1 part resin, 1 part hardener. Dries hard in 2 1/2 minutes, full cure in 24 hours. Machines well.
    Shrinkage seems to be about .001 per inch.
    If it doesn't work for the rails, I'll have to find another use for it.
    Mar 2004
    1661
    Go man, just go!
    (And for you guys not watching movies, that's from Dum Dumber. )
    Jan 2007
    355
    Thanks svenakela,
    Just needed a little motivation...
    (nuts)
    Feb 2004
    1086
    I also bet it will work -- if they are full length supports, they'll only be loaded in compression, and that loading will be spread over a huge surface area, so you shouldn't see much stress (and hence not much movement). Even for crappy plastic, you'll have an ultimate stress of ~1-4 ksi (as opposed to 45 ksi for aluminum). At a conservative 1 ksi, assuming your support is 1/2" wide, and your load is spread over 6" (for 3 square inches), you'd have to see 3000 lbs before failure, and probably 200 lbs before significant mushing of the material.
  1. RFQ-Polyurethane parts.
    By SCCoupe in forum Employment Opportunity
    Last Post: 09-19-2007, 05:40 PM
  2. Polyurethane / Aluminum Machinability ?
    By RMARCH in forum Material Machining Solutions
    Last Post: 07-24-2006, 12:53 AM
  3. Polyurethane enamel
    By MrRage in forum Uncategorised MetalWorking Machines
    Last Post: 12-27-2005, 06:03 PM
  4. Machining polyurethane?
    By MrHorsepower in forum Glass, Plastic and Stone
    Last Post: 12-08-2005, 07:27 AM
  5. Support For Gas Pipe Rails
    By Mr.Chips in forum DIY CNC Router Table Machines
    Last Post: 02-17-2004, 03:12 PM
