588,172 active members*
4,265 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > I need a certain Parameter number (Fanuc OT)
    Oct 2003
    38
    Most of our machines dont require you to input a decimal point after each number when programming. If you type in X100 in automatically turns it into X100.000. But we have a machine that doesnt do this so typing in X100 actually makes it X000.100.
    Obviously this can be a problem if certain monkeys miss out a decimal point and a tool go's to Z0.2 instead of Z200.0 ramming it straight into the jaws at 2000rpm
    (yes, someone did that last week :nono: )
    I know this can be changed with a certain parameter but I cant remember which
    Aug 2007
    10
    parameter 15 bit 7 should be 1
  1. Fanuc 3M DNC operation
    By max_c in forum Uncategorised MetalWorking Machines
    Last Post: 07-05-2010, 01:11 AM
  2. Parameter Fanuc System10T
    By saptoro in forum Uncategorised MetalWorking Machines
    Last Post: 03-21-2005, 02:38 PM
  3. Fanuc motor ???
    By jevs in forum Servo Motors / Drives
    Last Post: 03-16-2005, 11:47 PM
  4. FANUC coding compatability??
    By m1911bldr in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-24-2004, 11:10 PM
  5. help with fanuc 18i parameter list
    By bob1371 in forum Fanuc
    Last Post: 11-06-2003, 03:24 PM
